wsaenot
#1 Posted : Tuesday, April 14, 2020 12:22:19 PM(UTC)
wsaenot
Singapore
VMix has audio buses from A to G.
I will like to make use of buses C to F to create manual mix minus but I cannot seem to send audio to those buses. For audio bus A and B is easy as there is a simple button in the audio mixer section to make the selection but not for the rest of the buses.
raugert
#2 Posted : Tuesday, April 14, 2020 1:03:27 PM(UTC)
raugert
Canada
You need to "Enable" busses C-G by first going to the main Settings>Audio. Enable each buss (C-G) in the dropdown menus. Then restart vMix. Now when you go to the Audio Mixer, you right-click on any of the "MAB" buttons. Then select the busses you wish to assign to that input. It's a little tricky at first but you'll get it...
cheers,
Richard
thanks 1 user thanked raugert for this useful post.
wsaenot on 4/15/2020(UTC)
ralston
#3 Posted : Wednesday, April 15, 2020 12:10:51 AM(UTC)
ralston
Do you know Richard if it's possible to bring into vMix audio from a BUS output on a AIR XR 18 external mixer by any chance ? You can bring in audio channel inputs from the XR 18 via X-AIR ASIO Drivers which work great inside vMix for inputs 1/18
Just wondering about BUS outputs, is it possible to bring in a BUS ?
raugert
#4 Posted : Wednesday, April 15, 2020 3:17:11 AM(UTC)
raugert
Canada
Yes, theoretically it should work on any ASIO compatible device.
When you "Enable" the Bus in the Settings>Audio, choose the "ASIO Driver" from the pulldown instead of just 'enabling' the bus. Then from the pulldown next to the output selection, choose which ouput to send it to your device. I haven't tested it on X-Air but I just tried it on a UMC-404HD and it works OK. I'm assuming it would work on your Behringer device as well.
ralston on 4/15/2020(UTC)
ralston
#5 Posted : Wednesday, April 15, 2020 3:31:46 AM(UTC)
ralston
Thanks for the reply. I am able to receive audio from the INPUTS on the X-Air, my question if more for the BUS OUTPUTS being sent from the Air into the vMix audio inputs. So I would like to create a audio into within vMix that is being fed from a AIR BUS output. I hope thats not to confusing.
raugert
#6 Posted : Wednesday, April 15, 2020 4:13:09 AM(UTC)
raugert
Canada
Ah OK. Sorry I don't have an X-Air to play with, but I just browsed the X-Air manual and section 6.13 refers to routing. See if you can actually re-enter an Aux Out as an input to USB within the matrix.
Some mixer may do this, but it's really model dependent.
wsaenot
#7 Posted : Wednesday, April 15, 2020 11:30:16 AM(UTC)
wsaenot
Singapore
cheers,
Richard
Thank you very much, that really solve the issue. I could not find that in the vMix manual at all.
Similar Topics
Switch Audio Routing per channel (General Discussion)
by burie 1/5/2026 2:20:00 AM(UTC)
RodeCaster Pro - Audio routing (General Discussion)
by adambou 2/26/2025 9:35:16 PM(UTC)
Audio Routing Recommendations (General Discussion)
by MrMagoo 10/22/2023 5:31:43 PM(UTC)
Audio routing to combine vMix call and SRT streams (vMix Call)
by BriceMunn 12/19/2022 11:12:19 PM(UTC)
Audio Routing for Hybrid Event with Zoom (Feature Requests)
by ward@wardcameron.com 6/22/2021 2:18:19 AM(UTC)
Need Help w/ Audio Routing (General Discussion)
by massimiliano.t.d 2/20/2021 1:54:50 PM(UTC)
Audio Routing over 2 machines in vMix Call (vMix Call)
by PChoEdwards 1/21/2021 11:43:31 PM(UTC)
Vmix call Audio Routing (vMix Call)
by jcw718 8/14/2020 7:22:28 AM(UTC)
audio routing with dante (General Discussion)
by KRTW 8/1/2020 6:18:41 AM(UTC)
Advanced audio routing (General Discussion)
by shae-valleytech 6/22/2020 5:47:06 AM(UTC)
vMix & Zoom audio routing issues (General Discussion)
by Francois001 6/2/2020 6:16:28 AM(UTC)
VMix Audio routing (vMix Call)
by mixmexmax 5/18/2020 1:17:15 AM(UTC)
4 callers vmix call. audio routing-trigger on off to master (vMix Call)
Belarus SebG 5/4/2020 12:31:02 AM(UTC)
vmix call audio routing workflow (vMix Call)
by lighting video 3/31/2020 3:36:25 AM(UTC)
VMix for ISO Recorder with Sony xdcam codec and Audio Routing (3rd Party Software and Development)
by fahrul.azmi 3/6/2020 1:31:10 AM(UTC)
vMatrix audio routing (3rd Party Software and Development)
by thsorensen1 2/15/2020 9:02:53 AM(UTC)
Help with complex audio routing (General Discussion)
by ClementN 6/23/2014 4:28:36 PM(UTC)
Selectable audio routing for input modules (Feature Requests)
by richardgatarski 5/28/2014 11:28:30 AM(UTC)
