vMix Call
VMix Audio routing
Joined: 5/9/2020(UTC) Posts: 18  Location: Cologne Thanks: 1 times Was thanked: 3 time(s) in 2 post(s)
Is there any way to do this:
A show is running with a local host and one or more callers thru VMixCall. Can I send an audio signal (in that case a seperate Mic) to the callers only, without this beeing heard on the bus that is going out to the stream? Like instructions from the director...
Important: The automaic mix-minus feature of vmix call should not be lost or sacrificed! All ideas welcome. Thanks, Michael
Audio Bus is your friend Setup the Mic to Bus B and give Bus B to the callers only
vMix Call
VMix Audio routing
