vMix Call
Audio routing to combine vMix call and SRT streams
Joined: 1/11/2021(UTC) Posts: 14  Thanks: 3 times Was thanked: 2 time(s) in 2 post(s)
Forgive me, this problem has probably been asked many times but I can't find an exact description anywhere. I have an upcoming show where the master vMix machine is located remotely to all presenters. Most of the presenters will be on a simple vMix call input, however for better quality there will be 2 master studios sending a higher bandwidth SRT stream that'll have ~2 sec delay. To those studios I want to feedback a no-delay (ie v-mix call) video Mix Input + director track and return their audio when they're not live so director + host can have off-air conversation. What do you recommend? This is what I want to achieve:  Screenshot 2022-12-19 at 13.13.21.png (48kb) downloaded 1 time(s).I guess all this is possible if you can send different audio buses/video outputs to different callers on the same vMix call? Other option will be running Zoom calls alongside the vMix Call just for talkback? Thank you, Brice
Joined: 4/23/2017(UTC) Posts: 1,493  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
I suggest using buses for this. Each vmixcall can have it's own return audio. For callers talkback I solo myself so that they get the instructions with full attention. Dynamic inputs can also help.
vMix Call
