BriceMunn
#1 Posted : Monday, December 19, 2022 11:12:19 PM(UTC)
BriceMunn
Forgive me, this problem has probably been asked many times but I can't find an exact description anywhere.
I have an upcoming show where the master vMix machine is located remotely to all presenters. Most of the presenters will be on a simple vMix call input, however for better quality there will be 2 master studios sending a higher bandwidth SRT stream that'll have ~2 sec delay. To those studios I want to feedback a no-delay (ie v-mix call) video Mix Input + director track and return their audio when they're not live so director + host can have off-air conversation. What do you recommend?
This is what I want to achieve:
Screenshot 2022-12-19 at 13.13.21.png (48kb) downloaded 1 time(s).
I guess all this is possible if you can send different audio buses/video outputs to different callers on the same vMix call?
Other option will be running Zoom calls alongside the vMix Call just for talkback?
Thank you,
Brice
mavik
#2 Posted : Tuesday, December 20, 2022 5:47:35 AM(UTC)
mavik
Was thanked: 196 time(s) in 176 post(s)
I suggest using buses for this. Each vmixcall can have it's own return audio. For callers talkback I solo myself so that they get the instructions with full attention.
Dynamic inputs can also help.
Guest (5)
