9 Pages«<34567>»
MartLeib
#81 Posted : Saturday, October 26, 2019 10:10:47 PM(UTC)
MartLeib
Estonia
Originally Posted by: admin Go to Quoted Post
Originally Posted by: MartLeib Go to Quoted Post
Could you add advanced options to the SRT dialog? I would like to have control over maxbw, oheadbw and other settings that usually can be defined in the URL.
How is currently maxbw set relative to inputbw?
Also, logging would be awesome, currently did not find SRT related ffmpeg logs in the ProgramData vMix folder.
SRT in vMix is designed to (hopefully) be as simple as possible to setup and configure.
For that reason these settings will not be available as changing them from the defaults tend to cause more harm than good for the vast majority of use cases.
Also to answer your question, maxbw etc are all handled automatically by the SRT library and it tends to work quite well.
Thanks!
richardgatarski
#82 Posted : Sunday, October 27, 2019 12:53:16 AM(UTC)
richardgatarski
@Henny, as clearly stated in admin's first post in this topic here is not the place for Feature requests.
Luckily ;) there is already a FR to be voted/commented upon:
https://forums.vmix.com/...--as-a-source-for-Inputs
spencerm24
#83 Posted : Sunday, October 27, 2019 2:32:48 PM(UTC)
spencerm24
Did I dream this or did Martin say on the FTLS that we would be able to send any output to a stream. I can't seem to figure out how to do that on the 23 preview.
#84 Posted : Sunday, October 27, 2019 6:23:33 PM(UTC)
Was thanked: 4726 time(s) in 1618 post(s)
Note any output, either Output 1 or 2 in 4K and Pro editions.
See the source option here:
https://www.vmix.com/help23/StreamingQuality.html
alicinio
#85 Posted : Monday, October 28, 2019 8:09:50 PM(UTC)
alicinio
hi, i'm only speaking about decoding:
SRT decoding in HEVC as caller isn't working (from a cube 755 teradek) but works in vlc outside vmix
SRT decoding in H264 as caller is working but no audio and video stuttering but works in vlc oustide vmix.
Even adding srt latency or decoding latency don't fix the stutter or the audio.
The H264 encoder is a processionnal fujitsu ip9500e, it is a udp wrapped in a srt with the gihub haivision srt.
Whynot just add SRT in VLC FOR VMIX ?
thanks
#86 Posted : Monday, October 28, 2019 11:28:26 PM(UTC)
What are the computer specs? Did you try disabling hardware decoding?
alicinio
#87 Posted : Tuesday, October 29, 2019 12:19:49 AM(UTC)
alicinio
Yes i tried disable decoding,no success.
the pc were :
laptop xps13-9360 and nuc 8th generation with i7-8559U and 8GB ram
if i do the de-wrapp of SRT with linux sub system and then decode the stream in udp with vlc in vmix, it works (both H264 and HEVC) with audio, no stutters.
when i try in SRT directly in vmix, it doesn't work in HEVC, stutter and no audio with H264.
sam602
#88 Posted : Tuesday, October 29, 2019 12:35:56 AM(UTC)
sam602
Trinidad And Tobago
I can also confirm ..i did caller -》listener...vMix to vMix..public ips on both computers. The result video but no audio. HW enc/dec was on.
EDITED ... The error was all mine.. I got it to work and works beautifully
#89 Posted : Tuesday, October 29, 2019 12:52:31 AM(UTC)
Please drop us an email at info@vmix.com.au and send a support report from Settings -> About and we should be able to see what is happening.
alicinio
#90 Posted : Tuesday, October 29, 2019 2:48:32 AM(UTC)
alicinio
ok i sent you the report and email
thanks
alicinio
#91 Posted : Tuesday, October 29, 2019 4:10:12 AM(UTC)
alicinio
It is working now, i downloaded from the microsoft store the "HEVC Video Extensions" and now it is working like charm, no stutter and audio. but for H264 still stutter and no audios.
PeterH
#92 Posted : Wednesday, October 30, 2019 7:16:46 AM(UTC)
PeterH
vMix Media Converter
- adding files to conversion list takes very long, it seems that every file is read before appearing in the list
- option to set output drive/directory/filename would be nice
- option to convert multiple input files to one single output file, if you had set the new file every xxx minutes option in multicorder would be very important
- option to set output format, resolution and bit rate would be nice
- option to convert files which are in native ndi4 format
thanks 1 user thanked PeterH for this useful post.
PFBM on 10/31/2019(UTC)
PFBM
#93 Posted : Thursday, October 31, 2019 7:00:16 AM(UTC)
PFBM
Forum Rank:: Advanced Member
vMix Media Converter is incomplete :(
its transcoding to ProRes LT only....
can you put the 3 main options ?
ProRes LT, SQ, HQ.
also can it transcode with multichannel audio ?
Cheers,
PFBM
#94 Posted : Thursday, October 31, 2019 12:12:02 PM(UTC)
As LT is equivalent to the vMix AVI quality, it would just be wasting CPU resources to use a higher quality...
PFBM
#95 Posted : Thursday, October 31, 2019 1:44:22 PM(UTC)
PFBM
really ?
Complete name : vMixStorage\capture - 30 October 2019 - 03-43-52 PM.avi
Format : AVI
Format/Info : Audio Video Interleave
Format profile : OpenDML
File size : 1.37 GiB
Duration : 56 s 360 ms
Overall bit rate : 209 Mb/s
Video
Format : VMX1
Codec ID : VMX1
Bit rate : 207 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 FPS
Bits/(Pixel*Frame) : 1.996
Stream size : 1.36 GiB (99%)
Audio
Format : PCM
Format settings : Little / Signed
Codec ID : 1
Bit rate mode : Constant
Bit rate : 1 536 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Stream size : 10.3 MiB (1%)
Alignment : Aligned on interleaves
Interleave, duration : 20 ms (1.00 video frame)
Interleave, preload duratio : 20 ms
the transcoded file :
Complete name : vMixStorage\capture - 30 October 2019 - 03-43-52 PM.mov
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 0000.02 (qt )
File size : 931 MiB
Duration : 56 s 358 ms
Overall bit rate mode : Variable
Overall bit rate : 139 Mb/s
Writing application : Lavf58.20.100
Video
Format : ProRes
Format version : Version 0
Format profile : 422 LT
Codec ID : apcs
Duration : 56 s 180 ms
Bit rate mode : Variable
Bit rate : 137 Mb/s
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:2
Scan type : Progressive
Bits/(Pixel*Frame) : 1.326
Stream size : 920 MiB (99%)
Writing library : fmpg
Language : English
Audio
Format : PCM
Codec ID : sowt
Channel layout : L R
Bit depth : 16 bits
Language : English
Default : Yes
Alternate group : 1
i doubt a bit......
The target data rate of Apple ProRes 422 LT is approximately 102 Mbps at 1920 x 1080 and 29.97 fps.
The target data rate of Apple ProRes 422 HQ is approximately 220 Mbps at 1920 x 1080 and 29.97 fps.
there is always a quality loss with transcode.... why not lower the odds.... ?
is vmix codec 8 bit or 10 bit ?
cheers,
pfbm
#96 Posted : Thursday, October 31, 2019 6:46:23 PM(UTC)
23.0.0.22
http://cdn.vmix.com/download/vmix23preview.exe
* Fixed performance issue when playing video files due to changes in how FFMPEG is used.
* Fixed playback issue with some video formats such as HEVC.
* Added support for changing SRT key length for old encoders/decoders.
* SRT version updated to 1.4
* Added error message when attempting to send more than 8 channels of audio over SRT
* Fixed issue where one of the 6 or 8 audio channels encoded over SRT was set to encode as LFE (low frequency)
thanks 3 users thanked admin for this useful post.
Shilon on 11/1/2019(UTC), natzakaria on 11/2/2019(UTC), StepBackInTime_TV on 11/3/2019(UTC)
RastaCZ
#97 Posted : Saturday, November 2, 2019 9:55:58 PM(UTC)
RastaCZ
Mix shortcuts BUG: When using PreviewInput/ActiveInput shortcut for mix 2/3/4, the input parameter is always decremented by 2. e.g. shortcut should preview input 3 in mix 2, but in fact it preview input 1. Fade, Zoom, Wipe,.. shortcuts works as expected
giulliu
#98 Posted : Monday, November 4, 2019 12:22:33 AM(UTC)
giulliu
Hi to everyone,
I've try to use the mix input function that appear very interesting new entry.
When creating shortcut about it, the selection input appear shifted by 2 (to are able to select the input 1 it's necessary to set the input 3 on the shortcut input menu).
I wrong anything or there are a bug?
thanks 1 user thanked giulliu for this useful post.
sam602 on 11/4/2019(UTC)
AndrewRed
#99 Posted : Tuesday, November 5, 2019 5:10:16 AM(UTC)
AndrewRed
Originally Posted by: stevespaw Go to Quoted Post
How do I Assign inputs to the new C-G busses?...
Out of the v23 documentation (https://www.vmix.com/help23/Mixer.html): "To enable or disable mixes C-G right click the A or B buttons to display a selection menu."
Ouch,
It does work, but:
1. users will never "find" this. There is no indication of "right-clickableness".
2. no correct feedback.
I know this is some re-work, but it should be something like this:
The multiple Bus functionality is awesome, still trying to figure out the best way to configure and monitor multi-channel outputs and recording.
Thanks!!!
Steve
Totally agree on a better way to present this. Steve is spot on :) Great feature. Thank you!
Shilon
#100 Posted : Tuesday, November 5, 2019 6:13:48 PM(UTC)
Shilon
Israel
Is there anyway to inform us that there is a new beta build, other than searching all the threads in the post.
Guest (16)
9 Pages«<34567>»
