marcyaghi1
#1 Posted : Saturday, April 21, 2018 2:28:24 PM(UTC)
marcyaghi1
Afganistan
Hello
I need to make something on vmix
on key press in showtcuts
i need to execute an http url for example ; http://192.168.1.1/vmix.php
how to do this
in script ??
regards
BTW
this isnot working
Dim webStream As Stream
Dim webResponse = ""
Dim req As HttpWebRequest
Dim res As HttpWebResponse
req = CType(WebRequest.Create("http://10.1.2.56:8088/API/?Function=OverlayInput1In&Input=2"), HttpWebRequest)
res = CType(req.GetResponse(), HttpWebResponse)
webStream = res.GetResponseStream() ' Get Response
Dim webStreamReader As New StreamReader(webStream)
While webStreamReader.Peek >= 0
webResponse = webStreamReader.ReadToEnd()
End While
#2 Posted : Saturday, April 21, 2018 2:52:11 PM(UTC)
might be helpfull to know the intention in order to see if it's the right approach to begin with (ex Shortcut Y/N)
marcyaghi1
#3 Posted : Saturday, April 21, 2018 3:15:26 PM(UTC)
marcyaghi1
Afganistan
its a corn job execution command
URL is
http://192.168.1.1/wp-cr...=5&action=processing
this will update and excel file in the www folder
then data-source will be updated
i already checked this by Puting the above url in chrome , it worked and file is updated , i need to implement this as a key press in vmix
regards
#4 Posted : Saturday, April 21, 2018 3:33:04 PM(UTC)
not completely familiar as in not used yet but a HttpWebRequest would be the ticket , but i wonder why you try a script then with WebRequest.Create("http://10.1.2.56:8088/API/?Function=OverlayInput1In&Input=2"), in it instead of execute an http url for example ; http://192.168.1.1/vmix.php
as vMix scripting is based on vb.net one might google in this vb.net, HttpWebRequest and php direction
#5 Posted : Saturday, April 21, 2018 3:51:04 PM(UTC)
btw
if it is for updating a datasource why dont you just link to it with your datasource link ?
SImilar to another post of yours "vmix data source"
Similar Topics
Need help with URL Input keyboard input, Please help asap (General Discussion)
by knbPixels 5/9/2026 12:16:30 AM(UTC)
Data Source/Scripting Help (General Discussion)
by AndrewH 4/9/2026 2:13:15 PM(UTC)
Help with adding RTSP cameras inputs through API Calls (General Discussion)
by MartinC79 3/24/2026 2:51:41 AM(UTC)
Help with Dynamic Database Setup in Vmix (General Discussion)
by Tim P. 3/23/2026 7:12:35 AM(UTC)
Winner Third Help (GT)
by lehart 2/20/2026 3:26:29 AM(UTC)
help. mic wont work in output C (General Discussion)
by Streampunk 1/16/2026 2:21:54 AM(UTC)
Need help with NDI into vMix via Tailscale (NDI)
by knbPixels 1/14/2026 2:46:15 AM(UTC)
Help with Reference System (Systems)
by tayproductions 12/16/2025 6:07:49 AM(UTC)
Professional Help (General Discussion)
by Rfritz1208 11/20/2025 3:24:23 AM(UTC)
Need Help About InstantReplay (Instant Replay)
by kadry 10/29/2025 6:32:53 AM(UTC)
Can I get help with Decklink 8k Pro and MacM4 Here? (General Discussion)
by pedalquickly 8/25/2025 8:02:49 AM(UTC)
Where i find vcall files any please help me (vMix Call)
by bistari 8/8/2025 11:12:28 PM(UTC)
Help with List, Playlists for a lot of Commercials & Graphics (General Discussion)
by Tim P. 7/21/2025 12:37:39 PM(UTC)
NDI Scan Converter – Frame Drop on M1 iMac, Will M4/M3 Macs Help? (NDI)
by dwsk527 6/30/2025 1:20:57 PM(UTC)
Laggy High Render Times. Upgrade help? (Hardware Compatibility)
by Lastmarine 5/13/2025 7:05:19 PM(UTC)
Need help with GT and pages (display multiple pages simultaneously?) (GT)
by TL68 4/3/2025 7:24:11 PM(UTC)
Help for a beginner who would like to write simple scripts (General Discussion)
by visioneimmagine 4/2/2025 1:27:04 AM(UTC)
Shortcut buttons on home page... very helpful (Feature Requests)
by obau 3/30/2025 10:35:23 AM(UTC)
help me my vmix keeps crashing (General Discussion)
by kamlesh4623 3/28/2025 6:34:22 PM(UTC)
I need help with a trigger please. (General Discussion)
by Kapelaan 3/14/2025 5:18:09 PM(UTC)
Help me please to setup a 6 camera vmix computer. (Systems)
by Alessandro B 3/13/2025 1:49:28 AM(UTC)
ASL interpreter window template help (General Discussion)
by ab800 2/12/2025 4:19:34 AM(UTC)
Help Needed with SMTAV IP PTZ Cameras Positioning Issue (Hardware Compatibility)
by jacan sevada 1/13/2025 12:14:50 PM(UTC)
Help with Capture Card (Hardware Compatibility)
by stamperdog 12/14/2024 7:29:57 AM(UTC)
Live Stream Help (General Discussion)
by Lighthouse_Gosport 11/25/2024 2:42:25 AM(UTC)
Help Need! SOS - NDI one desktop can not see the other (NDI)
by gujingc 11/13/2024 7:23:40 PM(UTC)
External Render Card - Help SOS (General Discussion)
by gujingc 10/14/2024 9:54:24 AM(UTC)
BCF2000 Setup Help in vMix (Hardware Compatibility)
by coultersound 7/28/2024 1:59:52 AM(UTC)
Need help with MultiCoder (General Discussion)
by Dave Galegor 7/18/2024 7:41:43 AM(UTC)
Audio set up issues - please help (General Discussion)
by AimeeParnell 6/11/2024 4:26:12 AM(UTC)
