jvphobic
#1 Posted : Friday, January 26, 2018 12:07:49 PM(UTC)
jvphobic
Was thanked: 11 time(s) in 10 post(s)
A way to be able to copy triggers to other shots. Maybe right click and select "Copy Triggers" and then a paste option on other shots. I think that could be useful for times that I need to create a trigger on 40+ shots.
Thanks.
rowby
#2 Posted : Friday, January 26, 2018 9:56:09 PM(UTC)
rowby
+1 ...Rowby.
Jeffry_Ghost
#3 Posted : Tuesday, February 6, 2018 10:36:13 AM(UTC)
Jeffry_Ghost
Czech Republic
+1
Similar Topics
Changing Inputs on Triggers Via Scripts (General Discussion)
by ahen 8/28/2026 4:48:40 AM(UTC)
List Triggers (General Discussion)
by buntonn 6/17/2026 8:59:30 PM(UTC)
Triggers on many inputs (General Discussion)
by CoryL.NFLD 3/19/2026 10:11:50 AM(UTC)
ESC key should close “Select a Function” window in Triggers (Feature Requests)
by SeluZ 3/5/2026 9:52:46 PM(UTC)
Triggers for specific index in List input (Feature Requests)
by orwinetkins 1/24/2026 5:18:04 AM(UTC)
Make OnCountdownRemaining and OnCountdownComplete triggers work with the countdown to time function (Feature Requests)
by guidogast 11/3/2025 6:29:58 PM(UTC)
simplified use of triggers (Feature Requests)
by Murchik 10/28/2025 10:20:05 PM(UTC)
Triggers based off an input being used on a layer in program? (General Discussion)
by knbPixels 3/4/2025 8:12:53 AM(UTC)
Playback Time Triggers for photos input and live sources (Feature Requests)
by nikosman88 11/16/2024 5:45:28 AM(UTC)
Is there an API for triggers? (General Discussion)
by DThompson55 7/26/2024 1:53:26 AM(UTC)
Add “OnZoomCameraOn”/”OnZoomCameraOff” Triggers for Assigned Participant (Feature Requests)
by WaltG12 4/28/2024 4:18:07 PM(UTC)
Setting triggers with scripts (General Discussion)
by MSFTGuruGuy 3/15/2024 11:42:16 PM(UTC)
New triggers - audio on / audio off (Feature Requests)
by spinfold 2/20/2024 5:41:54 AM(UTC)
Triggers management options (Feature Requests)
by kardellivemedia 1/25/2024 1:25:06 PM(UTC)
Faster way to copy/paste triggers (Feature Requests)
by SethLT 1/12/2024 5:26:31 AM(UTC)
Triggers to activate /de-activate key shortcuts (Feature Requests)
by sdonn 1/4/2024 3:14:28 AM(UTC)
“Copy to” options for triggers (Feature Requests)
by mandurphy 12/28/2023 10:10:01 PM(UTC)
Shortcuts for Triggers (Feature Requests)
by Edy Santos 11/21/2023 10:39:47 PM(UTC)
VMix Triggers Part 2 (General Discussion)
by mattford1 11/6/2023 2:23:39 AM(UTC)
VMix Triggers (General Discussion)
by mattford1 11/6/2023 12:27:40 AM(UTC)
Shortcut To Deactivate Triggers (Feature Requests)
by shawntempesta 9/22/2023 6:55:31 AM(UTC)
Add triggers for recording start/stop (Feature Requests)
by fgolman 9/14/2023 3:05:09 PM(UTC)
Google Sheets Triggers (General Discussion)
by Ruben Blammo 9/3/2023 7:00:43 PM(UTC)
BUG report: vMix Triggers being ignored (General Discussion)
by Roy Sinclair 8/1/2023 9:11:12 AM(UTC)
Overlay that shows which triggers are activated (General Discussion)
by AuditorRSTO 7/20/2023 10:32:05 PM(UTC)
Replay Triggers (General Discussion)
by petengokeh 5/28/2023 8:19:59 PM(UTC)
Scoreboard triggers to title indicators from XML (General Discussion)
by MSFTGuruGuy 5/10/2023 4:22:49 AM(UTC)
Add OnPresetLoaded Triggers (Feature Requests)
by gpdipalmerahtimur 1/26/2023 3:53:46 PM(UTC)
Stream Triggers (Feature Requests)
by Guest 11/15/2022 12:14:51 AM(UTC)
any way to toggle triggers programmatically? (General Discussion)
by DThompson55 10/15/2022 5:57:05 AM(UTC)
