timothychew
#1 Posted : 12 years ago
timothychew
Dear
Anyone using Vmix for Full HD recording
I am using edius
what format is the best
the let the computer run less resource
and best quality
And Edit more smooth
macjaeger
#2 Posted : 12 years ago
macjaeger
You need a powerfull codec that is fast and doesn't use too much cpu cycles. Try Cineform.
timothychew
#3 Posted : 12 years ago
timothychew
Do I need to install something
I am now record using MTS
How do I know what codex I use
macjaeger
#4 Posted : 12 years ago
macjaeger
MTS is a container format, not a compression format.
I'm confused. When you use vMix to record your shows, you should already know the codec you use, as you selected it in the recording settings?
Anyway, a good tool to inspect media file formats would be "mediainfo".
Depends on what you already have. There is no single best codec for every purpose. But for any purpose there are some decent codecs, and some of them are even free. Cineform has very good quality and is very fast; Canopus HQ/HQX codecs have even better quality, but are slower. MJPEG is extremely fast (at least some implementations are), but you may experience quality loss, especially over several generations of re-encoding. For any codec there is a tradeoff between image quality and file size, and in realtime recording you also should think about the transfer speed of your harddrive(s) - a ssd or raid system might be necessary to achieve best quality at 1920x1080 (try blackmagic hard disk advisor to get the speed of your drives).
In any case you might want to read up on video formats and video editing - it's a complex topic, more than could be discussed in the forum.
P.S.: Could you please at least put questionsmarks behind questions? Sometimes it's really hard to guess what you mean.
timothychew
#5 Posted : 12 years ago
timothychew
OK thanks
Similar Topics
Vmix Recording Video footage at 2fps (General Discussion)
by Chintudhillon 2 years ago
Solution for putting marks in vMix recordings! (General Discussion)
by Eliot Hochberg 3 years ago
Internal Timecode for vMix Recordings (Update II) (Feature Requests)
by BETech 3 years ago
A problem in a Vmix recording (General Discussion)
by Dori 4 years ago
Audio sync issue between vMix recording and live stream (General Discussion)
by J Miller 4 years ago
Vmix recording crackling/clicking/popping (General Discussion)
by DJ Scholtes 5 years ago
Why can't my PC or Mac open vMix recordings all of a sudden? (General Discussion)
by ProSonas 5 years ago
vmix recording and file size (General Discussion)
by plizon 6 years ago
Timecode in vMix recordings (3rd Party Software and Development)
by rickb 6 years ago
Adding Markers On A vMix Recording (Feature Requests)
by MelissaR 6 years ago
VLC does not recognize vMix recording codec (General Discussion)
by rowby 7 years ago
Vmix recording quality issues solved (General Discussion)
by Duff TV 8 years ago
win10 - dual graphics laptop - vmix recording: Vmix one click performance monitor (Hardware Compatibility)
by h2video.nl 10 years ago
theme channels using vmix recordings (Showcase)
