8 Pages«<34567>»
StepBackInTime_TV
#81 Posted : Tuesday, February 28, 2017 6:07:07 AM(UTC)
StepBackInTime_TV
Rank:: Advanced Member
Was thanked: 17 time(s) in 14 post(s)
EXTERNALS:
vMix 19 is just brilliant! The only thing I could do with now are more Externals - right now, 4 externals would be perfect, but I am sure more would find good use in many productions. I will put this in the feature request forum, if it isn't already there :-)
madness
#82 Posted : Tuesday, February 28, 2017 9:06:11 AM(UTC)
madness
admin wrote:
madness wrote:
Ran into another issue with this build.
A crash means a driver problem or hardware fault somewhere, likely graphics.
The changes since 18 are not likely to contribute to this, especially of opening an older preset which won't be using any of the new features.
The problem is that the preset worked with the previous version of 19, and is now crashing with .30.
I had opened my preset just the night before, and without any windows updates occurring. The only change was vMix being updated.
#83 Posted : Tuesday, February 28, 2017 11:05:33 AM(UTC)
Was thanked: 4710 time(s) in 1614 post(s)
vMix 19 Preview Update (19.0.0.32)
http://cdn.vmix.com/download/vmix19preview.exe
* Fixed bug with new MultiView on/off checkbox
* Fixed problem with vMix Call return video when using interlaced frame rates
* Reduced vMix Call latency
* Added text boxes for manual Cropping adjustments
* Added 2560x1440 resolution
* Added Undo button up the top of vMix next to Preset that is visible after closing an input accidentally that will restore that input.
We're interested in hearing ideas of other things to enable "Undo" for in Feature Requests
* New Shortcuts!
MoveMultiViewOverlay -Change order
MultiViewOverlay/On/Off -Toggle on/off overlays
CallManagerShowHide
Fullscreen -Toggle on/off fullscreen
SetTransitionEffect - Change transition effect for each of the 4 buttons in UI
SetTransitionDuration - Change transition duration for each of the 4 buttons in UI
thanks 15 users thanked admin for this useful post.
DWAM on 2/28/2017(UTC), ON.tv Channels on 2/28/2017(UTC), madness on 2/28/2017(UTC), Stavlin on 2/28/2017(UTC), corporatejames on 2/28/2017(UTC), boris9831 on 2/28/2017(UTC), DYosua on 2/28/2017(UTC), sinc747 on 2/28/2017(UTC), ask on 3/1/2017(UTC), mjgraves on 3/1/2017(UTC), tonylightfoot on 3/1/2017(UTC), vijay6672 on 3/1/2017(UTC), stigaard on 3/1/2017(UTC), xaver on 3/1/2017(UTC), pba on 3/3/2017(UTC)
#84 Posted : Tuesday, February 28, 2017 11:24:49 AM(UTC)
Last switch to PGM ?
lol!
pba
#85 Posted : Tuesday, February 28, 2017 2:40:13 PM(UTC)
pba
Was thanked: 24 time(s) in 20 post(s)
Hey Man,
you made my day! :)
Peter
lol!
thanks 1 user thanked pba for this useful post.
boris9831
#86 Posted : Tuesday, February 28, 2017 5:24:41 PM(UTC)
boris9831
The UNDO button is great - I used it to recall the vMix call and it kept the same #. Also I noticed that these #s are also saved with presets. Can't wait to have my clients upgrade when this is officially released. Question - what does the "text boxes for manual Cropping adjustments" do? - Can't find it in the help file.
#87 Posted : Tuesday, February 28, 2017 5:31:17 PM(UTC)
They simply allow to crop by indicating values in pixels. It's great!
I wish we can also get this for zoom/scale in multiviews.
boris9831 on 3/2/2017(UTC)
sinc747
#88 Posted : Tuesday, February 28, 2017 11:56:42 PM(UTC)
sinc747
This new feature is a dream come true!!!! When I am cropping your video image to fit in a frame for my show, I can dial-in the crop 1/100 at a time. Before it was all drag and drop, and hope to get lucky.
Now I'm truly lucky!
- Tom
thanks 2 users thanked sinc747 for this useful post.
madness on 3/1/2017(UTC), boris9831 on 3/1/2017(UTC)
SHMD
#89 Posted : Wednesday, March 1, 2017 11:14:10 AM(UTC)
SHMD
Canada
Was thanked: 52 time(s) in 31 post(s)
Adding a zoom percentage of actual pixels would be amazing!
If you stay under 100% zoom you will not loose video quality. Great feature for 4K input to 1080 or 720 streams.
-sheldon
thanks 1 user thanked SHMD for this useful post.
madness
#90 Posted : Wednesday, March 1, 2017 11:57:02 AM(UTC)
madness
I've been wanting this too! Can't wait to try it out.
#91 Posted : Wednesday, March 1, 2017 12:11:53 PM(UTC)
There is a feature request for positioning and scaling all overlays with numerical values in multiviews.
If you like it, give it a +1
https://forums.vmix.com/....aspx?g=posts&t=8623
StepBackInTime_TV
#92 Posted : Wednesday, March 1, 2017 2:33:55 PM(UTC)
StepBackInTime_TV
I'm running vMix 4K and I don't get that option (vMix 19-32) - 1080p @ 4mbps is the highest, even if I set the production resolution to 4K.
G.
#93 Posted : Wednesday, March 1, 2017 10:24:18 PM(UTC)
Sorry for the confusion, it is a new resolution option for capture and output, not for vMix Call
madness
#94 Posted : Wednesday, March 1, 2017 11:20:42 PM(UTC)
madness
Martin, Just an FYI, You were absolutely correct. My Logitech C920 webcam driver had been corrupted on the USB3 port. Worked fine in a USB2 port in the front of the machine.
Uninstalled the device, did a reboot with it unplugged, and plugged it back in to reinstall, and it appears now to be working.
boris9831
#95 Posted : Thursday, March 2, 2017 3:10:33 AM(UTC)
boris9831
- Tom
Got it ! Thx Tom
spino
#96 Posted : Thursday, March 2, 2017 6:03:20 AM(UTC)
spino
Italy
Was thanked: 21 time(s) in 13 post(s)
* New Shortcuts!
GREAT!!! It works perfect. Thank you so much. Now it could be perfect if we could have the same function in activators.
danieloc
#97 Posted : Thursday, March 2, 2017 6:57:57 AM(UTC)
danieloc
Hello vMix friendos, am testing the preview19, trying to use the call function (that's something we truly wait for a long time) but I cant test it.
When I add the input call, a popup window it's showed with the message: "vMix Call is not available in this Edition of vMix"
Am a developer and have bean using vMix for years, am using a "Basic HD" license, do I need to upgrade? Is there any option to test this without upgrade? Any idea?
Thank you very much for all.
Dani
#98 Posted : Thursday, March 2, 2017 7:05:21 AM(UTC)
vMix HD or higher is needed at this time to test vMix Call, sorry about that.
danieloc on 3/2/2017(UTC)
#99 Posted : Thursday, March 2, 2017 7:07:15 AM(UTC)
Just made some improvements to how the vMix Call site works which should help punch through corporate firewalls a bit better (which tend to completely block UDP).
However, the vMix side of things will still need to be on a network that does not completely block UDP. (which is most networks we have encountered thankfully)
PFBM on 3/3/2017(UTC)
danieloc
#100 Posted : Thursday, March 2, 2017 7:43:49 AM(UTC)
danieloc
Thanks for the quick answer!
Do you think in the future will be available for other versions also?
Will we be able to manage this call feature by means of the API?
Dani
Guest (6)
8 Pages«<34567>»
