Joined: 4/22/2016(UTC) Posts: 83   Location: UK Thanks: 18 times Was thanked: 17 time(s) in 14 post(s)
EXTERNALS:
vMix 19 is just brilliant! The only thing I could do with now are more Externals - right now, 4 externals would be perfect, but I am sure more would find good use in many productions. I will put this in the feature request forum, if it isn't already there :-)
admin wrote:madness wrote:Ran into another issue with this build.
A crash means a driver problem or hardware fault somewhere, likely graphics. The changes since 18 are not likely to contribute to this, especially of opening an older preset which won't be using any of the new features. The problem is that the preset worked with the previous version of 19, and is now crashing with .30. I had opened my preset just the night before, and without any windows updates occurring. The only change was vMix being updated.
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
vMix 19 Preview Update (19.0.0.32)http://cdn.vmix.com/download/vmix19preview.exe* Fixed bug with new MultiView on/off checkbox * Fixed problem with vMix Call return video when using interlaced frame rates * Reduced vMix Call latency * Added text boxes for manual Cropping adjustments * Added 2560x1440 resolution * Added Undo button up the top of vMix next to Preset that is visible after closing an input accidentally that will restore that input. We're interested in hearing ideas of other things to enable "Undo" for in Feature Requests * New Shortcuts! MoveMultiViewOverlay -Change order MultiViewOverlay/On/Off -Toggle on/off overlays CallManagerShowHide Fullscreen -Toggle on/off fullscreen SetTransitionEffect - Change transition effect for each of the 4 buttons in UI SetTransitionDuration - Change transition duration for each of the 4 buttons in UI
 15 users thanked admin for this useful post.
DWAM on 2/28/2017(UTC), ON.tv Channels on 2/28/2017(UTC), madness on 2/28/2017(UTC), Stavlin on 2/28/2017(UTC), corporatejames on 2/28/2017(UTC), boris9831 on 2/28/2017(UTC), DYosua on 2/28/2017(UTC), sinc747 on 2/28/2017(UTC), ask on 3/1/2017(UTC), mjgraves on 3/1/2017(UTC), tonylightfoot on 3/1/2017(UTC), vijay6672 on 3/1/2017(UTC), stigaard on 3/1/2017(UTC), xaver on 3/1/2017(UTC), pba on 3/3/2017(UTC)
Quote:We're interested in hearing ideas of other things to enable "Undo" for in Feature Requests Last switch to PGM ? lol!
Rank:: Advanced Member
Thanks: 38 times Was thanked: 24 time(s) in 20 post(s)
Hey Man, you made my day! :) Peter DWAM wrote:Quote:We're interested in hearing ideas of other things to enable "Undo" for in Feature Requests Last switch to PGM ? lol!
 1 user thanked pba for this useful post.
Thanks: 24 times Was thanked: 6 time(s) in 5 post(s)
The UNDO button is great - I used it to recall the vMix call and it kept the same #. Also I noticed that these #s are also saved with presets. Can't wait to have my clients upgrade when this is officially released. Question - what does the "text boxes for manual Cropping adjustments" do? - Can't find it in the help file.
Quote: what does the "text boxes for manual Cropping adjustments" do? They simply allow to crop by indicating values in pixels. It's great! I wish we can also get this for zoom/scale in multiviews.
Joined: 8/2/2013(UTC) Posts: 1,099   Location: Fairhope, Alabama USA Thanks: 590 times Was thanked: 202 time(s) in 168 post(s)
boris9831 wrote:Question - what does the "text boxes for manual Cropping adjustments" do? - Can't find it in the help file.
This new feature is a dream come true!!!! When I am cropping your video image to fit in a frame for my show, I can dial-in the crop 1/100 at a time. Before it was all drag and drop, and hope to get lucky.
Now I'm truly lucky!
- Tom
 2 users thanked sinc747 for this useful post.
Joined: 10/1/2016(UTC) Posts: 117  Thanks: 88 times Was thanked: 52 time(s) in 31 post(s)
DWAM wrote:Quote: what does the "text boxes for manual Cropping adjustments" do? They simply allow to crop by indicating values in pixels. It's great! Adding a zoom percentage of actual pixels would be amazing! If you stay under 100% zoom you will not loose video quality. Great feature for 4K input to 1080 or 720 streams. -sheldon
 1 user thanked SHMD for this useful post.
DWAM wrote:Quote: what does the "text boxes for manual Cropping adjustments" do? They simply allow to crop by indicating values in pixels. It's great! I wish we can also get this for zoom/scale in multiviews. I've been wanting this too! Can't wait to try it out.
admin wrote:vMix 19 Preview Update (19.0.0.32) * Added 2560x1440 resolution
I'm running vMix 4K and I don't get that option (vMix 19-32) - 1080p @ 4mbps is the highest, even if I set the production resolution to 4K. G.
StepBackInTime_TV wrote: I'm running vMix 4K and I don't get that option (vMix 19-32)
Sorry for the confusion, it is a new resolution option for capture and output, not for vMix Call
madness wrote:admin wrote:madness wrote:Ran into another issue with this build.
A crash means a driver problem or hardware fault somewhere, likely graphics. The changes since 18 are not likely to contribute to this, especially of opening an older preset which won't be using any of the new features. The problem is that the preset worked with the previous version of 19, and is now crashing with .30. I had opened my preset just the night before, and without any windows updates occurring. The only change was vMix being updated. Martin, Just an FYI, You were absolutely correct. My Logitech C920 webcam driver had been corrupted on the USB3 port. Worked fine in a USB2 port in the front of the machine. Uninstalled the device, did a reboot with it unplugged, and plugged it back in to reinstall, and it appears now to be working.
sinc747 wrote:boris9831 wrote:Question - what does the "text boxes for manual Cropping adjustments" do? - Can't find it in the help file.
- Tom Got it ! Thx Tom
Joined: 12/20/2016(UTC) Posts: 191   Location: Milano Was thanked: 21 time(s) in 13 post(s)
* New Shortcuts!
GREAT!!! It works perfect. Thank you so much. Now it could be perfect if we could have the same function in activators.
Hello vMix friendos, am testing the preview19, trying to use the call function (that's something we truly wait for a long time) but I cant test it.
When I add the input call, a popup window it's showed with the message: "vMix Call is not available in this Edition of vMix"
Am a developer and have bean using vMix for years, am using a "Basic HD" license, do I need to upgrade? Is there any option to test this without upgrade? Any idea?
Thank you very much for all.
Dani
vMix HD or higher is needed at this time to test vMix Call, sorry about that.
Just made some improvements to how the vMix Call site works which should help punch through corporate firewalls a bit better (which tend to completely block UDP). However, the vMix side of things will still need to be on a network that does not completely block UDP. (which is most networks we have encountered thankfully)
admin wrote:vMix HD or higher is needed at this time to test vMix Call, sorry about that. Thanks for the quick answer! Do you think in the future will be available for other versions also? Will we be able to manage this call feature by means of the API? Dani
