2 Pages12>
cutter07
#1 Posted : Tuesday, June 24, 2014 3:16:47 PM(UTC)
cutter07
Would be helpful to have a shortcut and trigger function for "audio fade"
thanks 1 user thanked cutter07 for this useful post.
IceStream on 6/26/2014(UTC)
Bardos59
#2 Posted : Tuesday, June 24, 2014 5:13:36 PM(UTC)
Rank: Guest
Groups:
Have you tried Fade to Black? Audio fades with the video...and I do not know why anyone would want an 'auto fade' for audio anyway....most, if not all producers I have worked with prefer to do any fades in post, or do manual fades from the audio mixer that they are getting the feed from...I do, and that is how I was trained......
#3 Posted : Tuesday, June 24, 2014 8:30:15 PM(UTC)
I see the merits of cutter07's request, especially when transitioning from an opening sequence with BG music track or something similar. I like the music to slowly fade behind opening remarks and while it is preferable to do this manually as Bardos59 indicates, in a "one man" show it is not always practical to move the mouse around the screen as quickly as needed. Automating the process with a shortcut would be a good solution. I am not all that familiar with the current options available such as "Set Volume", "Audio", "Audio On" and "Audio Off" and if it is already possible to do this, but I suspect not (i.e. a slow 10 second fade of BG audio).
+1
cutter07
#4 Posted : Wednesday, June 25, 2014 8:32:49 AM(UTC)
cutter07
Exactly IceStream, for BG music I need the audio fade. I have a PlayList with intro video, title slides and fade to camera..., for this I play BG music until or before the camera faded in. To automate this I need an "audio fade" trigger on camera fade in.
Bardos59
#5 Posted : Wednesday, June 25, 2014 4:48:00 PM(UTC)
Rank: Guest
Groups:
In that case then, select "Automatically Mix Audio" in the Settings Menu...see if that does what you want.....
#6 Posted : Wednesday, June 25, 2014 9:18:16 PM(UTC)
@ Bardos59
The problem with auto mixing with transition is that once the transition is complete, the audio is gone as well.
If you have an audio track that you want to slowly fade out during a program intro, or after coming back from a break, the only way to do that now is manually (and yes, it is the preferred way in a professional environment with appropriate staffing).
If you do not have the staff and are not using an external mixer, you have to use the slider in the vMix Audio Mixer.
At the same time you may also want to cut from camera 2 to camera 1, or zoom in on a virtual set, or for that matter have to fade up the host's or guest's mic.
So my point is that in a "one man" operation, there are too many simultaneous things happening for you to keep your mouse on the fader to slowly fade the music out and cut between cameras and/or overlay a lower third and/or fade up talent microphones.
Having a shortcut key option to help "automate" the process makes the producer/director's job that much easier.
For that matter, it makes the "self" broadcaster/video blogger's "show" that much more "professional" if they can run their whole program simply by using a few hot keys and not have to worry about fading potentiometers up or down.
cutter07
#7 Posted : Thursday, June 26, 2014 5:21:24 AM(UTC)
cutter07
"Automatically Mix Audio" works only if the audio is embedded in the video input. So if you fade out the video the audio is still playing even with "Automatically Mix Audio" set. For me it would be perfect to set a trigger in the video input to fade a specified audio out.
Do you add the audio from an external mixer with video input embedded or as separate audio input? I prefer to do it separatly, then the "Automatically Mix Audio" want work when fading video out or in.
I think for Martin it's easy to expand vMix with this functionality.
StepBackInTime_TV
#8 Posted : Friday, April 22, 2016 10:46:55 AM(UTC)
StepBackInTime_TV
Was thanked: 17 time(s) in 14 post(s)
+1 Trigger to Fade a playing audio file, would be very helpful.
StreamTeamChris
#9 Posted : Wednesday, April 27, 2016 7:12:44 AM(UTC)
StreamTeamChris
I have also looked for a audio fade solution.
On smaller productions or a one man show, you may not have a audio technician, so a audio fade in shortcut would be alot more convenient to fade in a audio track instead of using a midi mixer or doing it manually with your mouse.
thanks 1 user thanked StreamTeamChris for this useful post.
stigaard on 4/27/2016(UTC)
#10 Posted : Wednesday, April 27, 2016 8:25:17 AM(UTC)
On a side note, it should be stated that it is possible to set up an audio fade with a sequence of multiple 'Shortcuts' and/or 'Triggers', but I still agree that it would certainly be a lot more convenient and practical to do it with just one "Function" command.
JAIRODJ
#11 Posted : Wednesday, April 27, 2016 9:19:37 AM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
It is possible the audio fade, I do.
Only Vmix 17 creates this audio fade, other versions have failed
In the section triggers its INPUT, you should stringing depending on whether you want to transition IN or OUT transition.
TRIGGER-------------FUNCTION-----INPUT------DURATION---DELAY---VALUE
On transition OUT--Set volumen--your input----10--------------80--------100
On transition OUT--Set volumen--your input----10--------------80--------90
On transition OUT--Set volumen--your input----10--------------80--------80
On transition OUT--Set volumen--your input----10--------------80--------70
On transition OUT--Set volumen--your input----10--------------80--------60
- Change the values (DELAY) according to the speed of molten wishing
- Change the values (VALUE) that amount of volume they want to get off
- Add more to zero
ENJOY
thanks 1 user thanked JAIRODJ for this useful post.
stigaard on 4/28/2016(UTC)
Cpilcher
#12 Posted : Wednesday, April 27, 2016 9:23:08 AM(UTC)
Cpilcher
+1
I have a need to adjust audio to predetermined levels. Not really fading audio out or in completely (although that would be very handy as well). I am constantly adjusting levels for commentary and bringing down the background audio when the commentators go live. It would be nice to be able to punch a button on my MIDI controller and ramp up commentary mic and bring down background audio via shortcuts. I have it set up with an On/Off shortcut now but I still prefer to use the sliders to gradually bring it in over time.
Chuck
Cpilcher
#13 Posted : Wednesday, April 27, 2016 10:20:52 AM(UTC)
Cpilcher
- Add more to zero
ENJOY
I can't wait to give this a shot. I tried something similar but couldn't get the results I was looking for. Thanks for the inspiration.
lbgaus
#14 Posted : Wednesday, April 27, 2016 10:24:52 PM(UTC)
lbgaus
- Add more to zero
ENJOY
This would work, yes, but it would be so much prettier and cleaner if there was a shortcut that could accept a target volume level and a time parameter. This actually brings to mind, it would also be really nice to fade up or out an audio capture input instead of clicking the "Audio" button and having it immediately jump up to full volume. In the cases when you have audio entering vMix when not tied to a video input...
richardgatarski
#15 Posted : Sunday, September 18, 2016 3:27:58 AM(UTC)
richardgatarski
+1
Video Dave
#16 Posted : Sunday, September 18, 2016 7:38:47 PM(UTC)
Video Dave
+1
vhai
#17 Posted : Thursday, September 29, 2016 9:18:52 PM(UTC)
vhai
If you have scripting access, as a rude workaround you may use the following code to fade out a audio input until there is a built-in fade function:
Code:
dim bgmi = Input.Find('BackgroundMusic')
dim i
for i=100 to 0 step -1
  sleep(40)
  bgmi.Function("SetVolume", i)
next i
thanks 4 users thanked vhai for this useful post.
sinc747 on 9/29/2016(UTC), Amokka on 11/24/2016(UTC), daniel514 on 5/18/2017(UTC), R_L on 4/13/2021(UTC)
sinc747
#18 Posted : Wednesday, November 9, 2016 5:02:42 PM(UTC)
sinc747
+1
kol0
#19 Posted : Wednesday, November 9, 2016 5:04:25 PM(UTC)
kol0
Was thanked: 8 time(s) in 8 post(s)
+1
Amokka
#20 Posted : Wednesday, November 9, 2016 5:09:29 PM(UTC)
Amokka
Was thanked: 18 time(s) in 13 post(s)
+ 1
Trigger a function to set [input] volume level to [%] in a time span of [xxxx] miliseconds.
Would be a very useful function in a lot of scenarios
Similar Topics
how to trigger audio fade out? (General Discussion)
by Streampunk 10/8/2024 5:16:34 PM(UTC)
Change audio faders scale (Feature Requests)
by papaswan 11/7/2023 6:27:49 PM(UTC)
Audio fader shortcut tweak (Feature Requests)
by nomski 11/22/2022 7:04:35 PM(UTC)
Audio fade between Cuts (Feature Requests)
by AlphaLiveJames 5/30/2022 4:32:48 PM(UTC)
Audio Fades on Triggers/Shortcuts (General Discussion)
by shampton 10/8/2021 3:33:32 AM(UTC)
MasterAudio Fade (General Discussion)
by james_kille 2/28/2021 7:09:03 AM(UTC)
Overlay audio fade not working (General Discussion)
by A_palmre 2/25/2021 1:03:16 AM(UTC)
How to include an audio fade on a shortcut (General Discussion)
by solo16 10/12/2020 2:27:50 AM(UTC)
Audio Fade Triggers Action (General Discussion)
by gpdipalmerahtimur 6/5/2020 7:06:46 PM(UTC)
Audio Fade Script: API.XML Audio Numbers in a different scale to Volume Shortcut Scale (3rd Party Software and Development)
by aircooled76@gmail.com 9/9/2018 12:31:26 PM(UTC)
Add Input #s to Audio Faders like Video Previews (Feature Requests)
by Jim_C 6/7/2018 12:23:20 AM(UTC)
Automate audio fade (General Discussion)
by Reinaldo 4/20/2018 3:09:14 PM(UTC)
Grouping Audio Faders (General Discussion)
by nowski 8/17/2017 4:45:36 AM(UTC)
Auto Audio Fade (Feature Requests)
by colintve 6/22/2017 6:41:02 PM(UTC)
Audio Fade out (Feature Requests)
by Crud577 5/6/2017 9:47:43 PM(UTC)
Audio Fade/Merge in Preview? (General Discussion)
by Midith316 11/2/2016 9:06:55 PM(UTC)
Audio Fade In / Out (Feature Requests)
by RichShumaker 9/2/2016 1:18:13 PM(UTC)
Audio Fade In/Out Hotkey (Feature Requests)
by jaredquinn 7/11/2016 7:25:16 PM(UTC)
Adding the optional Audio Fader & AFV to the Video Input Display. (Feature Requests)
by BETech 3/28/2016 7:48:42 AM(UTC)
Question about midi controller, audio faders, and live production. (General Discussion)
by Jim_C 10/2/2015 11:54:02 PM(UTC)
vMix 16 Audio Fader Behavior (General Discussion)
by admin 8/6/2015 5:14:58 AM(UTC)
Tip: How to play background music over different inputs with audio fade (General Discussion)
by cutter07 5/17/2015 3:16:45 PM(UTC)
Audio Fade and Overlay Transition (Feature Requests)
by BeBeINC 11/30/2013 12:55:04 PM(UTC)
Audio fader for Desktop Capture? (Feature Requests)
by Robk 11/25/2013 7:24:14 PM(UTC)
FTB function with audio fade in/out (General Discussion)
by dawidlorek 10/12/2013 7:56:35 AM(UTC)
2 Pages12>
