cutter07
#1 Posted : Sunday, May 17, 2015 3:16:45 PM(UTC)
cutter07
If you like to play background music over different inputs simply add the background music to every input under Multiview:
The music will play nicely without stopping until you fade an input to the output without or with something else as audio in the MultiView tab.
The background music should have "Automatically Mix Audio" ticked on
Example Video
Silas
