I would like to add input with a specific input number, or/and change the input rather than close and re-add.
The is important for TITLES as I have a number of TITLE xaml pages but just want to allocate 1 input for graphics and load xaml pages as required to the same input.
Adam
Joined: 10/13/2012(UTC) Posts: 1,157  Location: Melbourne Thanks: 220 times Was thanked: 200 time(s) in 181 post(s)
The change can be done by selecting the "change" button on the General Tab of the input settings screen. To create the specific input number you create the input and then drag and drop to re-order/re-number. I don't think that this can be automated but you might like to check the API documentation in help.
You might also like to look at using a LIST input. Again check the documentation for this and when using still images ensure you have turned off Automatically play next item.
