Add Input an image and mantain original size
Joined: 6/29/2011(UTC) Posts: 316   Location: Florida Thanks: 6 times Was thanked: 35 time(s) in 34 post(s)
atpt, Of course you can use the properties panel to re-size and position or what I would do is to create a image in photo shop that matches the size of vMix project i.e. 1280x720 with transparent background and place the 100x50 object in the preferred location then export as a PNG file with alpha
