Egriswold
#1 Posted : Thursday, July 4, 2013 1:02:33 PM(UTC)
Egriswold
Was thanked: 33 time(s) in 32 post(s)
atpt,
Of course you can use the properties panel to re-size and position or what I would do is to create a image in photo shop that matches the size of vMix project i.e. 1280x720 with transparent background and place the 100x50 object in the preferred location then export as a PNG file with alpha
