offroadmediagroup
#1 Posted : Tuesday, October 6, 2026 8:47:32 AM(UTC)
offroadmediagroup
We really need to be able to have audio limiters on both inputs, buses, and main outputs for purposes of not offending client requirements for output levels.
Mathias Schneider
#2 Posted : Thursday, October 8, 2026 12:14:54 AM(UTC)
Mathias Schneider
Germany
You can do that today without waiting for a feature: vMix loads VST3 plugins per input, per bus and on the master. Open the audio settings (gear icon) of the input, bus or master and add the plugin there. For a limiter that keeps you inside a client's level spec in the stream and the recording, two free ones that behave well in vMix:
LoudMax (Thomas Mundt) – a transparent brickwall limiter with just threshold and output ceiling. Put it on the master, set the ceiling to the level the client wants, done.
TDR Limiter 6 GE – more control (soft/hard knee, lookahead, separate peak and loudness stages) if the spec is stricter.
If the spec is in LUFS rather than peak, add Youlean Loudness Meter 2 (free) on the master as well, so you can see integrated loudness while the show runs.
Different story if the problem is the room: you arrive somewhere, the house PA is whatever it is, and your vMix output has to sound right on it. That is not a limiter question but a system-processing one. I build a free tool for exactly that, MixDesk X: a software DriveRack that runs on the vMix PC itself. It takes the vMix master via a virtual audio device, you shoot the room with pink noise and the RTA, the auto EQ flattens the PA, and each output bus has its own crossover, delay alignment, feedback destroyer and limiter. So the stream stays clean inside vMix (VST3), and the hall gets its own corrected, limited feed without a second computer or a hardware rack. macOS and Windows, no cost: adelvo.io/mix-desk-x
Order of attack for your case: VST3 limiter on the master first, that solves the client-level requirement. MixDesk X only if the venue is part of the problem.
offroadmediagroup
#3 Posted : Thursday, October 8, 2026 12:20:15 AM(UTC)
offroadmediagroup
You're missing the whole point. Of course, you download Waves and inject what ever plugin you want... But that's a third party, another point of failure, another licensing mechanism, etc.
We're talking about basic production tools for a production mixer that is already a huge part of the production world. They already have gain, EQ, compressor (albeit a poor one), matrix routing, bus mixing, etc... A soft limiter would be right in line with what they are already doing and would benefit the whole industry to maintain proper output levels and prevent clipping or squashed output once it hits a third party's system.
Mathias Schneider
#4 Posted : Thursday, October 8, 2026 1:26:16 AM(UTC)
Mathias Schneider
Germany
Fair point, and I would take a native brickwall too. My guess why it is not there: once you build the limiter, the LUFS meter, the gate and the de-esser are next, and that is exactly the list VST3 was meant to cover. Not a reason against the request, just why I would not wait for it.
Small correction only: the two I named are free, no Waves, no licence server, just a file in the VST3 folder. So until it is built in, that is the zero-cost way to stay inside a client's spec today.
offroadmediagroup
#5 Posted : Thursday, October 8, 2026 2:15:20 AM(UTC)
offroadmediagroup
Most VST's that production will 'want' to use are a purchased plugin, and typically require licensing... But fair'nough... there's free options out there.
The thing that somebody like my team think about is server load and job rolls of machines. We typically don't like 3rd party integrating into vMix... We've been burned before with plugins crashing vMix.
Mathias Schneider
#6 Posted : Thursday, October 8, 2026 5:28:49 AM(UTC)
Mathias Schneider
Germany
Fair enough, and I get the "burned by plugins" part. I just work differently: audio leaves vMix into a separate processor and gets streamed after that, and I test every piece hard before it goes near a show. Plenty of people run external interfaces, desks or a software mixer next to vMix for the same reason. Different workflows; yours is a good argument for having it native. +1.
