Joined: 8/29/2015(UTC) Posts: 136 Location: Seattle Wa
Thanks: 16 times Was thanked: 14 time(s) in 13 post(s)
ive followed instructions and watched video Tutorials, i can make virtual audio cable work outside of vmix, but when i add audio input in vmix, i get heavily distorted audio, i have many ways of outputting it to different devices, still dont work. Maybe theres a new problem with vmix? Help and Merry Christmas to All
Rank: Guest
Groups: Guests
Would be happy if you give your setup....just saying that it is distorted can mean many things, but I believe you should do the following first...
Check your input levels to vMix...check also to see if you have your input in 'aux' or 'mic'.......
im not shure how to do a system info dump, i7 windows 10 pro im useing the line input from virtual audio cable.[img][/img] File Attachment(s):  vac setup.PNG (3,046kb) downloaded 26 time(s).You cannot view/download attachments. Try to login or register.
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 592 times Was thanked: 203 time(s) in 169 post(s)
What is the source of the audio for Line input 1? Is that audio level too hot?
- Tom
i was useing vlc media player in the photo, but i have tried adobe audition and foobar 2000. same problem, it is a setting in vmix im shure, cause like i said earlier it works outside of vmix, thanks
Rank: Guest
Groups: Guests
I looked at the image you posted, and the audio level from the VLC player is way too hot, you need to lower that to about 50%, and then go into the audio settings for the vMix input, and check the audio input levels,
thats what it sounds like, but i adjust the levels in vmix and windows and there is no change,so many fine adjustments, this is not a very easy thing to do? i went from vlc out line 1 to audio repeater then out of that line 4 then used adobe audition to record line 4 wich would be like adding line 4 as a input in vmix, the recording went fine in adobe, vmix still a loud hot mess.
well it's working now, i un installed and re installed. allways forget that will fix most issues. thank you all for the help. have a great day!
While I have a license for VAC I switched to using VoiceMeeter Banana since it was introduced a year ago. It's not entirely as capable, but it's dramatically easier to use. It's more like a traditional audio mixer, with multiple virtual devices. Doesn't hurt that it's free and not licensed.
Michael
 3 users thanked mjgraves for this useful post.
