hellokitty
#1 Posted : Saturday, December 26, 2015 3:18:40 PM(UTC)
hellokitty
ive followed instructions and watched video Tutorials, i can make virtual audio cable work outside of vmix, but when i add audio input in vmix, i get heavily distorted audio, i have many ways of outputting it to different devices, still dont work. Maybe theres a new problem with vmix? Help and Merry Christmas to All
Bardos59
#2 Posted : Saturday, December 26, 2015 3:44:21 PM(UTC)
Rank: Guest
Groups: Guests
Would be happy if you give your setup....just saying that it is distorted can mean many things, but I believe you should do the following first...
Check your input levels to vMix...check also to see if you have your input in 'aux' or 'mic'.......
hellokitty
#3 Posted : Saturday, December 26, 2015 4:02:36 PM(UTC)
hellokitty
im not shure how to do a system info dump, i7 windows 10 pro im useing the line input from virtual audio cable.[img][/img]
File Attachment(s):
vac setup.PNG (3,046kb) downloaded 26 time(s).
sinc747
#4 Posted : Saturday, December 26, 2015 5:55:35 PM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
What is the source of the audio for Line input 1? Is that audio level too hot?
- Tom
hellokitty
#5 Posted : Saturday, December 26, 2015 6:02:31 PM(UTC)
hellokitty
i was useing vlc media player in the photo, but i have tried adobe audition and foobar 2000. same problem, it is a setting in vmix im shure, cause like i said earlier it works outside of vmix, thanks
Bardos59
#6 Posted : Saturday, December 26, 2015 6:23:07 PM(UTC)
Rank: Guest
Groups: Guests
I looked at the image you posted, and the audio level from the VLC player is way too hot, you need to lower that to about 50%, and then go into the audio settings for the vMix input, and check the audio input levels,
hellokitty
#7 Posted : Saturday, December 26, 2015 7:44:44 PM(UTC)
hellokitty
thats what it sounds like, but i adjust the levels in vmix and windows and there is no change,so many fine adjustments, this is not a very easy thing to do? i went from vlc out line 1 to audio repeater then out of that line 4 then used adobe audition to record line 4 wich would be like adding line 4 as a input in vmix, the recording went fine in adobe, vmix still a loud hot mess.
hellokitty
#8 Posted : Saturday, December 26, 2015 8:50:27 PM(UTC)
hellokitty
well it's working now, i un installed and re installed. allways forget that will fix most issues. thank you all for the help. have a great day!
mjgraves
#9 Posted : Saturday, December 26, 2015 9:52:18 PM(UTC)
mjgraves
While I have a license for VAC I switched to using VoiceMeeter Banana since it was introduced a year ago. It's not entirely as capable, but it's dramatically easier to use. It's more like a traditional audio mixer, with multiple virtual devices. Doesn't hurt that it's free and not licensed.
Michael
thanks 3 users thanked mjgraves for this useful post.
sinc747 on 12/27/2015(UTC), hellokitty on 12/27/2015(UTC), rowby on 9/13/2018(UTC)
Similar Topics
Virtual Audio Cables with vMix, Zoom, and Skype (General Discussion)
by mgrayeb 2/3/2020 5:28:06 PM(UTC)
Crackling Audio Using Virtual Audio Cables and Zoom (General Discussion)
by mgrayeb 3/3/2018 12:16:16 PM(UTC)
Virtual audio cable and VMix (General Discussion)
by migueis 11/2/2014 4:38:08 PM(UTC)
