Groups: Joined: 9/15/2013(UTC) Posts: 168  Location: Barbados Thanks: 14 times Was thanked: 14 time(s) in 13 post(s)
Where can I find the Web Controller for vMix....I did a search, but can not seem to find it
Open the shortcuts menu. Check out Tom Sinclairs latest video as well. (towards the end!) Also check you have enabled the Web Controller in the setting menu
Rank: Staff
Groups: Registered, Administrators Joined: 12/13/2012(UTC) Posts: 243 Location: Gold Coast, Australia
Thanks: 7 times Was thanked: 159 time(s) in 72 post(s)
The Web Controller settings are in the Settings section of vMix. You then need to enter the address located there into the browser of a device on the same network as the vMix computer. He have a guide here- http://www.vmix.com/know...sing-vmix-web-controller
What I am saying is that I do not see the Web Controller in the settings window.....I remember using it in ver:10 and ver:11, but for some reason I do not see it now.....Have not used it in a while....
Rank: Staff
It used to be just called 'Web' in the settings menu. Do you see that in your version?
Tes, I see it, and I now see it in the ver:16 on my laptop, but I just can not see the controller to use it
Rank: Staff
What happens when you enter the Web Address into the browser of a device connected to the same network?
 1 user thanked vmixsupport for this useful post.
I got it working on the same PC, I now have to get my network thingy sorted out......I am using a wireless router, so I have to try to figure out what I am not doing, or doing wrong that it is not working over the network......Thanks.....
UPDATE...Got my issues sorted out...I was the idiot...forgot I have to connect my phone to the network, so now, I have full control using my smart phone....love it....Thanks again
