Web Controller - No more custom images in display ? Wt?
Joined: 8/24/2019(UTC) Posts: 48  Location: Montreal Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
We use to be able to change the images of the thumbnails that we choose to display in the web controller These where the choices we had under the "Display" drop down menu on the shortcut/edit page Comming straight from the Vmix user guide here : https://www.vmix.com/hel...m?ControllerOptions.htmlDefault: The standard button with text.
Colour: Customise the background colour of the standard button with text.
Image: Select a custom image file to display in place of the button. The image will be stretched to fit the button dimensions.
Thumbnail: Display a thumbnail preview of the Input's contents at the time when the Web Controller page was last refreshed.Now the is only two choices : either Default or Thumbnail ... What's up with that ? I have the VMIX pro version - Build 23.0.0.60 -L
Ok so I think I found the problem.
When the shortcut I wish to appear in the Web Controller is mapped to a Streamdeck button, then the problem appears.
The display menu then shows only two choices :
Default Thumbnail
If I map the same shortcut to a normal keyboard key let say F2 , then the normal menu appears.
Default Colour Image Thumbnail
That clearly looks like a bug. Can someone confirm this ?
