LucaL
#1 Posted : Monday, September 21, 2020 12:15:15 AM(UTC)
LucaL
Canada
We use to be able to change the images of the thumbnails that we choose to display in the web controller
These where the choices we had under the "Display" drop down menu on the shortcut/edit page
Comming straight from the Vmix user guide here : https://www.vmix.com/hel...m?ControllerOptions.html
Default: The standard button with text.
Colour: Customise the background colour of the standard button with text.
Image: Select a custom image file to display in place of the button. The image will be stretched to fit the button dimensions.
Thumbnail: Display a thumbnail preview of the Input's contents at the time when the Web Controller page was last refreshed.
Now the is only two choices : either Default or Thumbnail ... What's up with that ?
I have the VMIX pro version - Build 23.0.0.60
-L
LucaL
#2 Posted : Monday, September 21, 2020 1:27:14 AM(UTC)
LucaL
Canada
Ok so I think I found the problem.
When the shortcut I wish to appear in the Web Controller is mapped to a Streamdeck button, then the problem appears.
The display menu then shows only two choices :
Default
Thumbnail
If I map the same shortcut to a normal keyboard key let say F2 , then the normal menu appears.
Default
Colour
Thumbnail
That clearly looks like a bug. Can someone confirm this ?
