Web Controller Link not working
Hi All,
I've been setting up Vmix this morning and when I come to check the web controller, the link doesn't work. I've opened up the port in my firewall but the link just doesn't load.
Any suggestions?
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
Are you opening it on the same network or remotely?
Go to the Settings> Web Controller menu and check you have enabled it.
Same network, and it is enabled.
Joined: 7/19/2017(UTC) Posts: 45  Thanks: 11 times Was thanked: 14 time(s) in 7 post(s)
A few questions:
* What exactly happens when you try to load it in a browser? Fails? 404? Do you have a console output from your browser? (To check what headers are being returned) * Are you prompted for a username/password? * Have you relaunched vMix? (I'm toying with controller/API now and sometimes it needs a kick)
Joined: 9/9/2020(UTC) Posts: 97  Location: Noord-Brabant Thanks: 3 times Was thanked: 13 time(s) in 12 post(s)
Can you try to access it from the machine that is running vmix with the URL from the settings menu Try than to do the same but replace the IP address to 127.0.0.1 If you are able to access it (specially on 127.0.0.1) than is a firewall active that is blocking the traffic from external to the machine
