davebtw
#1 Posted : Tuesday, October 20, 2020 9:26:51 PM(UTC)
davebtw
Hi All,
I've been setting up Vmix this morning and when I come to check the web controller, the link doesn't work. I've opened up the port in my firewall but the link just doesn't load.
Any suggestions?
Vince Beck
#2 Posted : Wednesday, October 21, 2020 12:22:15 AM(UTC)
Vince Beck
Are you opening it on the same network or remotely?
ask
#3 Posted : Wednesday, October 21, 2020 5:32:15 AM(UTC)
ask
Go to the Settings> Web Controller menu and check you have enabled it.
davebtw
#4 Posted : Wednesday, October 21, 2020 10:26:44 PM(UTC)
davebtw
Same network, and it is enabled.
NewsworthyVision
#5 Posted : Wednesday, October 21, 2020 11:46:13 PM(UTC)
NewsworthyVision
Was thanked: 14 time(s) in 7 post(s)
A few questions:
* What exactly happens when you try to load it in a browser? Fails? 404? Do you have a console output from your browser? (To check what headers are being returned)
* Are you prompted for a username/password?
* Have you relaunched vMix? (I'm toying with controller/API now and sometimes it needs a kick)
Pepsi(~)
#6 Posted : Thursday, October 22, 2020 5:00:41 AM(UTC)
Pepsi(~)
Netherlands
Can you try to access it from the machine that is running vmix with the URL from the settings menu
Try than to do the same but replace the IP address to 127.0.0.1
If you are able to access it (specially on 127.0.0.1) than is a firewall active that is blocking the traffic from external to the machine
