8 Pages<1234>»
r@wisla
#21 Posted : Thursday, August 6, 2015 11:24:23 AM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
I can't wait to check this new script feature. Looking forward for some examples, samples, tutorials...
So far I checked few commands from this topic http://forums.vmix.com.a....aspx?g=posts&t=3816 and it's not working
Code:
Overlay(1).In("scorebug.xaml")
<- it's OK
But
Code:
Input("Virtual Input").Cut
or
Code:
Input("scorebug.xaml").SetText("Doing Something")
Error Line 2: BC30456: 'Cut' is not a member of 'vMix.Scripting.Internal.Input'
Error Line 2: BC30456: 'SetText' is not a member of 'vMix.Scripting.Internal.Input'
What am I doing wrong? :)
#22 Posted : Thursday, August 6, 2015 11:41:47 AM(UTC)
Was thanked: 4749 time(s) in 1632 post(s)
Documentation and examples are coming soon, but for now some quick examples:
Input("Virtual Input").Function("Cut")
Input("scorebug.xaml").Text = "Doing Something"
r@wisla on 8/6/2015(UTC), thomas on 9/1/2015(UTC)
madness
#23 Posted : Thursday, August 6, 2015 11:52:26 AM(UTC)
madness
Loving this update for the Merge and the MIDI capabilities alone.
The shortcut "Find" is very handy!
Would love to use the scripts, but sadly I don't have licensing for 4K or Pro.
Thanks for the update Martin!
r@wisla
#24 Posted : Thursday, August 6, 2015 12:04:27 PM(UTC)
r@wisla
Thanks, I'm waiting for the documentation
...however, I cannot help asking how to indicate the text field in my xaml (text index or text name) ;-)
#25 Posted: : Thursday, August 6, 2015 12:34:26 PM(UTC)
Input("scorebug.xaml").Text("TextFieldName") = "Doing Something"
ovinas
#26 Posted : Thursday, August 6, 2015 12:50:08 PM(UTC)
ovinas
admin wrote:
Just waiting to hear on what you discover with the ASIO output issue. So far I have tested Focusrite, Behringer, Creative and ASIO4All with the output.
Just hooked up a Focusrite Saffire 6 USB and ASIO is working without problems.
So I checked the MOTU again, made a quite simple set-up with 6 ins and 6 outs, checked this with Waves Tracks Live, working perfect in ASIO mode. Same problem still with vMix: Interface to vMix working fine, vMix to interface nothing at all.
#27 Posted : Thursday, August 6, 2015 1:06:53 PM(UTC)
Hi Ovinas,
Check the vmistorage\logs folder to see if the logs there contain any errors when using the MOTU output.
You can also click the i button in the Master mixer to see if it is dropping samples
ovinas
#28 Posted : Thursday, August 6, 2015 1:50:50 PM(UTC)
ovinas
Played a bit with buffer settings of the interface without success. Even with the safest settings it's not working.
I've attached the screenshots of the logs (why 2 files?) and the audio info.
ovinas attached the following image(s):
ovinas
#29 Posted : Thursday, August 6, 2015 1:59:55 PM(UTC)
ovinas
And the same with 2 (working) audio inputs.
#30 Posted : Thursday, August 6, 2015 8:55:23 PM(UTC)
Thanks, I think I know what is happening with the output, will post a fix soon.
PFBM on 8/6/2015(UTC)
PFBM
#31 Posted : Thursday, August 6, 2015 9:41:22 PM(UTC)
PFBM
I think for a Software to use Asio technology ,
all the audio inside of the app should be asio controlled , ins and outs.
just like any daw.
Cheers,
PFBM
#32 Posted : Friday, August 7, 2015 10:19:42 AM(UTC)
16.0.0.48 has been uploaded
http://www.vmixhd.com/download/vmix16preview.exe
This should hopefully fix ASIO output issues with some devices and also improve merge functionality for some input layouts.
Len56 on 8/7/2015(UTC)
cutter07
#33 Posted : Friday, August 7, 2015 11:35:53 AM(UTC)
cutter07
Here two merge situations
At the end of merging picture two to four the transition in not completely smooth - i hope you can see what i mean
Merge with overlapping fotos
I would recommend to change the layer position to the top layer instead of fade if the picture aren't overlapping - if possible
Merge without overlapping fotos
thanks 1 user thanked cutter07 for this useful post.
madness on 8/7/2015(UTC)
Len56
#34 Posted : Friday, August 7, 2015 11:40:50 AM(UTC)
Len56
HI Martin,
I can confirm that the latest fix of the ASIO drivers are now working with my X32 Producer.
One thing I did find was on my X32 I have the sample rate setup to 44.1kHz, when I opened vMix and I added an audio input the audio was sounding garbled so I went into settings > audio and the Master Sample Rate was set to 4800kHz so I changed that to 44100kHz and restarted vMix and the garbled sound was gone, all working fine.
ovinas
#35 Posted : Friday, August 7, 2015 12:26:52 PM(UTC)
ovinas
Well done! MOTU UltraLite AVB now working in ASIO mode.
Are there any plans for MIDI data from vMix to the controller e.g. setting LEDs?
thanks 1 user thanked ovinas for this useful post.
PFBM
#36 Posted : Friday, August 7, 2015 5:00:03 PM(UTC)
PFBM
Len56 wrote:
HI Martin,
Remember that 48 khz is the standard audio for video , not 44.1 :)
Cheers,
PFBM
#37 Posted : Friday, August 7, 2015 5:58:28 PM(UTC)
I am simply blown away with the continuous improvements being made in vMix with each release!
Well done Martin.
I am still in agreement with Richard on the 'fade' behavior with the new "Merge" transition.
I wont pretend to understand the technical reasons behind it, and as much as I love the transition, I think the 'fade' spoils the overall effect and I would be reluctant to use it in certain situations for that reason. I much prefer the look of Thremir's Virtual Set Zoom Script, although that is not nearly as simple to set up, it just 'looks' better.
http://forums.vmix.com.a...ts&m=10215#post10215
I love all the additions and changes to the "Shortcuts" feature.
Not sure if it is a 'bug' or oversight, but with an abundance of 'Shortcuts', my "reference page" is over cluttered (see image below)
Is there a way to clean this up and/or a way to possibly "Print" these 'Templates' reference pages?
All in all, I am excited to explore many of the new features of vMix 16.
madness
#38 Posted : Friday, August 7, 2015 6:59:07 PM(UTC)
madness
I must agree as well. The fade through merge just doesn't look right in the examples above. Thankfully, I can't picture using it with that many inputs, and the overlaps as shown there unless that problem can be overcome.
#39 Posted : Friday, August 7, 2015 10:31:28 PM(UTC)
@ madness
Your video link is "Private" as opposed to "Unlisted".
(if this was intentional, I apologize, it's just that it's not viewable for the rest of us)
You present great examples of the 'merge' transition concerns that have been raised.
I don't want to call it an 'issue' or 'problem' since it is behaving precisely how it was designed, it just doesn't 'look' right to me.
I am not sure if a "fix" is possible and the 'fade' might be as good as it gets at this point, but I just think it would look better if both inputs were at 100% Opacity throughout the transition and maybe enable a quick fade if layers are crossed in the process.
(But then again, that is getting into some pretty sophisticated high end image processing special effects and probably into a league that vMix is not yet competing in)
h2video.nl
#40 Posted : Saturday, August 8, 2015 8:07:41 AM(UTC)
h2video.nl
Does Vmix 16 use a different desktop capture program to be installed on the other computer (win and Apple0 or is the existing one to be used.
I red that this important function is improved so I want to test it right away...)
greetings,
Stefan
Guest (4)
8 Pages<1234>»
