hi im new to all this program so sorry if this is an obvious q but when ever i put vmix into fullscreen on my laptop i cant get out of it without using the 3 finger salute ie contol alt delete & ending the fullscreen program but that shuts everything ... please advise cos otherwise this seems pretty cool cheers
Joined: 1/13/2010(UTC) Posts: 5,317  Location: Gold Coast, Australia Was thanked: 4719 time(s) in 1617 post(s)
Hi Buzz,
The fullscreen feature is designed to be used with two displays so that vMix is on your laptop screen and fullscreen is on a separate monitor or projector. That said, if you use the fullscreen on the laptop window you should still be able to press the windows key on the keyboard, click the vMix icon and then click the green Fullscreen button to turn of Fullscreen.
Martin vMix
hi thanx for the reply.. easy when u know how .. loving the program, great bit of kit, keep up the good work
