buzz
#1 Posted : Tuesday, January 17, 2012 8:44:30 PM(UTC)
buzz
hi im new to all this program so sorry if this is an obvious q but when ever i put vmix into fullscreen on my laptop i cant get out of it without using the 3 finger salute ie contol alt delete & ending the fullscreen program but that shuts everything ... please advise cos otherwise this seems pretty cool
cheers
#2 Posted : Wednesday, January 18, 2012 3:19:23 AM(UTC)
Was thanked: 4734 time(s) in 1624 post(s)
Hi Buzz,
The fullscreen feature is designed to be used with two displays so that vMix is on your laptop screen and fullscreen is on a separate monitor or projector.
That said, if you use the fullscreen on the laptop window you should still be able to press the windows key on the keyboard, click the vMix icon and then click the green Fullscreen button
to turn of Fullscreen.
buzz
#3 Posted : Friday, January 20, 2012 12:37:02 AM(UTC)
buzz
hi thanx for the reply.. easy when u know how .. loving the program, great bit of kit, keep up the good work
Similar Topics
Some Newbie Questions (General Discussion)
by BoxMan_Actual 4/19/2023 8:52:31 AM(UTC)
Newbie with just a few newbie questions (General Discussion)
by skirsch 10/30/2022 2:22:51 PM(UTC)
newbie question: how to set output back to program output (General Discussion)
by jurijus01 8/8/2021 11:20:16 PM(UTC)
Old PC many sources newbie question (General Discussion)
by tikacademy 4/16/2021 1:54:46 AM(UTC)
NEWBIE question on timers and counters (General Discussion)
by tikacademy 11/9/2020 3:47:13 AM(UTC)
Newbie question - sorry (General Discussion)
by timmed 8/14/2019 8:59:41 AM(UTC)
Newbie question about single audio source to a mix.. (General Discussion)
by jpdesroc 1/19/2016 12:00:44 PM(UTC)
Newbie question - Does this system sound reasonable? (General Discussion)
by crooker 4/20/2014 12:51:50 AM(UTC)
WMS Streaming in vMix? (newbie question) (General Discussion)
by krayg123 7/16/2013 7:40:58 AM(UTC)
Newbie Question re Capture cards (General Discussion)
by jstevens 6/29/2013 11:39:53 AM(UTC)
newbie questions for VM8 (General Discussion)
by mmorlan62 1/23/2013 5:54:49 PM(UTC)
Newbie questions. (General Discussion)
by mironhtu 2/21/2012 3:01:34 PM(UTC)
