WMS Streaming in vMix? (newbie question)
I currently use VidBlaster with 3 Full HD cameras, powerpoint grabber, etc, and am looking to change (for various reasons). One of these reasons is that the developer has decided to drop WMS streaming, and just basically keep flash instead. I know that most people just use a CDN for their broadcasts so flash is fine, but I have my own VPS dedicated to Windows Media Services, and it is important that I can stream to it. I can't afford to purchase a flash server at $4,500 :)
I have tried the trial version of vMix, and it appears that vMix does not support WMS streaming? Is this correct?
If someone could help me, that would be great, as at the moment that is a deal-breaker for me, and I will need to stay with an older version of VidBlaster for WMS, which I would rather not have to do.
Thanks!
Joined: 1/13/2010(UTC) Posts: 5,317  Location: Gold Coast, Australia Was thanked: 4719 time(s) in 1617 post(s)
You can use the WMV Streaming option in the Recording Setup window in vMix. Note that this runs in "Pull Mode" so you will need to make sure the streaming server supports it.
Alternatively you can select the vMix Video and vMix Audio sources in Expression Encoder to stream that way.
Martin vMix
Thanks Martin. I will take a closer look - I didn't see that originally, so I must have missed it.
Looks like the pull is not appropriate for me, but having expression encoder getting its input from the virtual device, encoding, and pushing is probably the way to go.
Thanks.
