dustink568
#1 Posted : Sunday, December 7, 2014 6:26:07 PM(UTC)
dustink568
I am trying to import an alpha channel overlay animation created in After Effects. What is the correct file format and video format for this to work?
Thanks,
Dustin
PS
This goes for all video formats also.
#2 Posted : Sunday, December 7, 2014 7:24:19 PM(UTC)
Was thanked: 509 time(s) in 478 post(s)
@ dustink568
MOV and AVI will work with alpha channel provided you render them properly in AE.
#3 Posted : Sunday, December 7, 2014 7:30:25 PM(UTC)
@ dustink568
dustink568
#4 Posted : Sunday, December 7, 2014 9:22:41 PM(UTC)
dustink568
What is the proper render settings for MOV and AVI with Alpha Channel in AE?
#5 Posted : Sunday, December 7, 2014 9:39:13 PM(UTC)
You have to insure you are rendering out the alpha channel, the default settings do not usually include alpha or audio (at least for me in AE CS5) so it renders as a "custom" setting once you make those adjustments.
DYosua
#6 Posted : Monday, December 8, 2014 7:28:27 PM(UTC)
DYosua
Was thanked: 14 time(s) in 12 post(s)
In the "Output Module" Settings (accessible from the Render queue once you add your Composition to it) there should be an option to select which channels you want to render under "Video Output." I believe the default is "RGB" but in your case you would want "RGB + Alpha." That should embed the alpha channel in the file. When you import the file in vMix, you will need to check the box that says "Video contains Alpha Channel" in the Input Select menu.
Similar Topics
Blackmagic Decklink Quad HDMI returns Unsupported Video Format (Hardware Compatibility)
by wassers 5/23/2025 6:14:11 PM(UTC)
UltraStudio 3G - Video Format not supported (General Discussion)
by floh 11/3/2023 5:02:35 AM(UTC)
Help - Video format is not supported (General Discussion)
by 4kUser 4/1/2023 7:23:36 AM(UTC)
Blackmagic mini monitor 4K: Unsupported video format (Hardware Compatibility)
by nidarosvideo 7/18/2020 12:44:31 AM(UTC)
Silly question about video formats (General Discussion)
by MickeyMJJ 1/18/2020 8:12:35 AM(UTC)
Blackmagic Mini Monitor - Unsupported video format (Hardware Compatibility)
by spencerm24 8/6/2018 6:42:44 PM(UTC)
Best video format for pre recorded video content (General Discussion)
by nakedeye 7/2/2018 6:09:29 AM(UTC)
What video format for Elgato HD60S and Canon T2i (Hardware Compatibility)
by KeepitRealRN 2/8/2018 12:38:46 PM(UTC)
Selected Video Format is not supported by this device (General Discussion)
by puruzio 8/20/2017 3:21:24 PM(UTC)
Most acceptable standard definition video format to put on a flash drive for playback on a computer? (General Discussion)
by Braindead 5/11/2016 12:01:18 PM(UTC)
Tested 12 video formats in vMix, Results. MP2, .m2ts, .mkv have no sound: AC3 solution (General Discussion)
by darp 5/7/2015 4:04:13 PM(UTC)
video formate (General Discussion)
by muhammad 2/28/2015 1:41:01 AM(UTC)
blackmagic -- video Format (General Discussion)
by isahlawi 12/14/2014 12:22:09 PM(UTC)
