Joined: 12/7/2014(UTC) Posts: 17  Location: USA Thanks: 2 times
I am trying to import an alpha channel overlay animation created in After Effects. What is the correct file format and video format for this to work?
Thanks,
Dustin
PS
This goes for all video formats also.
Joined: 3/7/2012(UTC) Posts: 2,688  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ dustink568
MOV and AVI will work with alpha channel provided you render them properly in AE.
@ dustink568
What is the proper render settings for MOV and AVI with Alpha Channel in AE?
You have to insure you are rendering out the alpha channel, the default settings do not usually include alpha or audio (at least for me in AE CS5) so it renders as a "custom" setting once you make those adjustments.
Joined: 2/24/2014(UTC) Posts: 45   Location: Maine, USA Thanks: 26 times Was thanked: 15 time(s) in 12 post(s)
In the "Output Module" Settings (accessible from the Render queue once you add your Composition to it) there should be an option to select which channels you want to render under "Video Output." I believe the default is "RGB" but in your case you would want "RGB + Alpha." That should embed the alpha channel in the file. When you import the file in vMix, you will need to check the box that says "Video contains Alpha Channel" in the Input Select menu.
