jbrenner3
#1 Posted : Saturday, August 30, 2014 3:29:55 PM(UTC)
jbrenner3
Is it possible to Render the external outputs back to the GPU, our GPU can handle 6 Displays, Id like to have 5,
1)Control
2)Preview
3)Output
4)Fullscreen (aux 1)
4)Fullscreen (aux 2)
Thank You
Jackster
#2 Posted : Saturday, August 30, 2014 8:32:27 PM(UTC)
Jackster
You can do it this way, bit of a hack job but works.
There will be a small delay, few frames to half a second.
Go into Output settings and set it to something like this.
Open up something like VLC and open a capture device (Ctrl + C)
Set it to the VMix video (for output) and Vmix external 2 for Aux2.
Should then see video, maybe a few frames to half a second behind though.
That what you were after? Maybe Martin needs to add more fullscreens to vMix IDK :P
jbrenner3
#3 Posted : Saturday, August 30, 2014 8:44:15 PM(UTC)
jbrenner3
Thank you very much. I stumbled upon this work around by accident a few hours ago. It would work if I were the only one running it however it's too many steps at startup to get it working every time. A lot of my users wouldn't be able to handle opening up 2 vlc's and setting the capture card.
If vmix had 4 full screens that would be perfect. Or at least a dedicated program out and preview out. Using the 2 fullscreen outs is awesome as auxiliaries. It's a shame to waste them on output and preview. Especially with the leaps and bounds that the GPU market has excelled in the last few months. 6 monitors on one card is no big deal anymore.
crooker
#4 Posted : Saturday, August 30, 2014 9:33:07 PM(UTC)
crooker
Pardon my newbieness (New to VMix, I've been playing with VMix but have yet to use it in production). When I was running VMix 12, I was sure I had all three of my monitors set to output... Main for the VMix window, Fullscreen as a Multiview and Fullscreen 2 as PROGRAM Out.
However, since VMix three, I can only set one full screen output.
I'd really like to get back to using my three local displays again. When I launch the settings, I can not see Fullscreen 1 and Fullscreen 2...
What am I doing wrong?
Thanks in advance for your help. It's greatly appreciated.
[[EDIT]] I see now that FS2 is only available in the 4K version. I must have had it working when I was in demo. Ahh well...
I definitely appreciate that a 4K tier should have more features (like multi-corder)... however, I think maximum amount of displays should be an HD feature, as it's a bit of a necessity when you're operating a 3, 4 or more cam setup. :)
Similar Topics
Decklink Duo 2 - 3 External Outputs (Hardware Compatibility)
by Puawai Productions 6/27/2026 10:18:14 AM(UTC)
26.0.37 - External Outputs error (General Discussion)
by nicademus 2/11/2023 12:40:56 PM(UTC)
The vertical output feature would be perfect for full screen and external outputs. (Feature Requests)
by efeozguryildirim 12/15/2022 5:04:58 AM(UTC)
More fullscreen/external outputs (Feature Requests)
by SRVBC Video 6/27/2022 5:41:42 AM(UTC)
How to reduce Video bitrate using external outputs to Decklin playback card (General Discussion)
by Francis Pam 3/18/2022 10:12:52 AM(UTC)
Declink Quad 2 and external outputs (Hardware Compatibility)
by justameh 3/12/2022 8:27:57 AM(UTC)
Request: Additional hardware external outputs (AUX) (Feature Requests)
by Owallen 2/16/2022 1:41:48 AM(UTC)
how many external outputs? (General Discussion)
Belarus freefishday 12/24/2021 4:13:18 PM(UTC)
Label External Outputs (Feature Requests)
by semaphore 3/6/2021 12:29:07 PM(UTC)
Warning in External Outputs dialogue (Feature Requests)
by tom@24bit.io 2/27/2021 5:21:15 PM(UTC)
external outputs, MultiView Display (Feature Requests)
by moratatv 10/6/2020 5:39:54 AM(UTC)
Extra external outputs (Feature Requests)
by carlofornasari 6/10/2020 7:36:10 PM(UTC)
vMix streaming/external outputs (General Discussion)
by kgoodyer 1/30/2020 11:27:32 AM(UTC)
Number of external outputs (Feature Requests)
by i.yaropolov 1/23/2019 5:08:10 PM(UTC)
All external outputs - the behavior of the inputs is the same as for Program (Feature Requests)
by snapoid 6/9/2018 10:32:59 AM(UTC)
Why only 2 external outputs? (Feature Requests)
by roverradio 7/26/2017 5:52:18 PM(UTC)
More External Outputs (Feature Requests)
by StepBackInTime_TV 2/28/2017 6:21:33 AM(UTC)
External Outputs (General Discussion)
by markk 3/31/2016 9:35:37 AM(UTC)
locking external outputs together (General Discussion)
by Ittaidv 1/18/2016 7:17:18 PM(UTC)
FADE Option for Fullscreen and External Outputs (Feature Requests)
by epicenter800 11/20/2015 7:14:22 PM(UTC)
Assign overlays to external outputs (as AUX output in videomixers) (General Discussion)
by homeless 8/27/2015 12:53:02 PM(UTC)
Two External Outputs with Different Content? (General Discussion)
by pjordan 2/26/2015 5:16:42 PM(UTC)
External Outputs in vMix 10 (General Discussion)
by THPI 8/4/2013 2:25:40 PM(UTC)
Multiple external outputs? (General Discussion)
by krayg123 7/17/2013 11:25:22 PM(UTC)
External Outputs > Audio Delay (General Discussion)
by dcoffey3296 2/28/2013 2:43:08 PM(UTC)
