vMix guide shows 'vMix 4K and higher supports 2x Fullscreen and 4x External outputs', however, in setting many it shows only two external menu( external 1 +external2).Where and how to setup external 3 and 4?
Joined: 10/6/2020(UTC) Posts: 98  Was thanked: 21 time(s) in 21 post(s)
Outputs 3 & 4 are 'virtual' outputs in the sense that they don't give you extra physical outputs, but two extra destinations which can then be used for NDI output, Streaming or Recording.
Joined: 8/2/2013(UTC) Posts: 1,109   Location: Fairhope, Alabama USA Thanks: 603 times Was thanked: 204 time(s) in 170 post(s)
Thanks: 187 times Was thanked: 20 time(s) in 17 post(s)
Use the cog wheel icon next to the External button at the bottom of the screen to find nos. 3 and 4.
