52 Pages«<4748495051>»
Luis70
#961 Posted : Tuesday, May 7, 2024 6:43:14 AM(UTC)
Luis70
Grenada
Anything to release as yet?....waiting for that update to use...
raugert
#962 Posted : Wednesday, May 8, 2024 10:13:52 PM(UTC)
raugert
Canada
Still working on a few updates and new features. Hope to have something late next week. ...
Richard
Luis70
#963 Posted : Thursday, May 9, 2024 8:18:21 AM(UTC)
Luis70
Grenada
Thanks...waiting patiently .... as you know this is my favourite app
mairginter@hotmail.com
#964 Posted : Monday, May 20, 2024 5:03:36 PM(UTC)
Italy
@raugert first of all, many thanks for your super app i love it and can no longer imagine doing without it.
One question, is it possible to save the scaling/zoom in the Windows app somewhere or add it to the config file?
I have a 24” 1080P touch monitor in the studio, so that I can keep the standard size of the buttons, I set the zoom factor to 70%. On the way I use a 14” 1080P monitor where the standard size works great.
Thanks Alex
Luis70
#965 Posted : Tuesday, May 21, 2024 1:23:34 PM(UTC)
Luis70
Grenada
Hi guys, did something like this some years ago, and decided to re-do it for use with single monitor PC setup......
I also use another layout where the Preview window is covered, as I seldom use, and that layout give me larger preview and output monitors, ... which layout do you all like....
Screen Capture.jpg (3,012kb) downloaded 55 time(s).
The blank area top right has the words 'ON LINE', 'RECORD' and MULTICORD'...they Tally so that I know what is actually going on .....
barryondeck
#966 Posted : Sunday, May 26, 2024 1:16:26 AM(UTC)
barryondeck
First of all, I don't know if Richard is married but damn it Richard I'm in love with you for coming up with such an amazing app and putting in all this work FOR SO LONG - and putting up with so many dumb questions, requests, and pushy/ungrateful people. If there is a virtual tip jar that I can throw some money in please point me to it, I'm happy to to contribute.
I was wondering if it's possible to add custom faders and vu meters, much like we can add custom icon buttons?
Forgive me if this was covered but I couldn't figure out how to search just this topic (I did search the forum for "custom slider" but didn't find anything)
Thanks again Richard, you're doing the lords work here my friend.
Luis70
#967 Posted : Sunday, May 26, 2024 7:54:42 AM(UTC)
Luis70
Grenada
The images seen in those photos were taken some time ago....but I must say, vMix Panel Builder is the BEST thing that happened to vMix......Richard did a proper app....and what I like about it, I can place my buttons where I want them, label them How I like, ...the perfect app...
raugert
#968 Posted : Monday, May 27, 2024 1:06:08 AM(UTC)
raugert
Canada
Thanks for the accolades. I've previously looked into having 'custom' skins for Faders and Vu's but it becomes tricky where the VU levels and the background need to be properly designed in order to represent the audio levels..
I'm just finishing up a new update, but I can revisit the Fader and VU's backgrounds in the future. Thanks for using the app..
barryondeck
#969 Posted : Monday, May 27, 2024 5:23:28 AM(UTC)
barryondeck
No worries.
Happy to help if that’s possible. I spent 20 years in I.T. , have some decent programming skills, and am pretty well skilled with Affinity Designer.
Not sure if it’s as easy as you tell me what the design parameters are for the current fader and I can work on a new test fader that can replicate that, that could be turned into a template - or if it’s way more complicated than that.
But I’d be happy to pitch in if possible (and my limited knowledge will allow).
Thanks again for the app and your hard work.
barryondeck
#970 Posted : Tuesday, May 28, 2024 2:36:51 PM(UTC)
barryondeck
Is there a particular place where I should put in a support ticket or bug reports?
I've hit my first snag: When using "Stinger1" as a transitoinI don't get my tally icons, but using "cutdirect" or "cut" works just fine and I do get the tally icon that I set.
Thanks.
#971 Posted : Friday, May 31, 2024 4:21:46 AM(UTC)
Well i started to play with panel builder, must say pretty cool and usefull raugert
My current main objective is instant replay control, first snag i hit was when i select another channel there is no feedback (Tally type)
Any tricks i missed ?
The current selected channelmode though is available from the vMix API
raugert
#972 Posted : Saturday, June 1, 2024 9:01:51 AM(UTC)
raugert
Canada
Hi doggy. Thanks for checking out the app.
I will look into the Replay functions and see what I can include for "Tallies" or feedback info according to what is available in the API XML. I hadn't put a lot of focus on Replay functions in previous versions.
I've been working on a new release that's almost ready, so I might release it first and then work on adding more Replay features. I can add the "tally" for channel selection for now as that's fairly easy...
cheers,
Richard
#973 Posted : Sunday, June 2, 2024 1:28:06 AM(UTC)
cheers,
Richard
Thank You Richard for looking into this
I can wait :-) as i am still brainstorming and testing about the actual procedures to invole for my "special" project
While i usually create custom external apps to control and get info your application looks very promissing to be used instead
so far the channel and camera selection "tallies" (not replay event cameras) and events(lists) seem most important and available from the api xml
Recording and live are allready available
Doggy
raugert
#974 Posted : Monday, June 3, 2024 9:33:51 AM(UTC)
raugert
Canada
UPDATE: Version 4.0.62
https://cli.re/VMPB-4.0.62
Change log:
fixed PGM/PVW tallies in setButtonColor when layers are set
fixed tally when using * in InputName
removed autohilite on IconButtons to prevent flashing when a "tally Icon" is selected
BitFocus buttons are now compatible with new format intoduced inBitFocus3.3(Page,Row,Column) --use Bitfocus version 3.4.0 Beta for compatibility
replaced "SetButtonColor to TitleColor" with "Set ButtonTally to TitleText" (set the text in a placeholder "Title" to true or false in order to trigger a button tally. This now allow user to program button tallies in the usual way in the PB "InfoBox" without having to assign colors in the Title's Rectangle objects). The "SetButtonColor to TitleColor" still works for now.
added dropdown menu to select "Sync IP" when using multiple networks
Tempate "Zoom" settings are now saved with template
added "ReplaySwapChannels" to command list
added latest vMix 27 shortcuts to Panel Builder commands list
added BusXSendToMaster tally
added BusXSolo tally
added SoloPFL tally
added ReplaySelectChannelA, B, AB tallies
added ReplayACamera, ReplayBCamera,ReplayCamera tallies
added ReplaySelectEvents1-20 tallies
Improved overall response
enjoy,
Richard
#975 Posted : Monday, June 3, 2024 5:49:20 PM(UTC)
Change log:
enjoy,
Richard
Hi Richard
Sweet
Allow me some feedback
ReplayACamera, ReplayBCamera tallies work fine , ReplayCamera doesnt seem to respond
If possible to add ReplayPlay and Pause tallys ?
There is a General problem; One has to select as input the name of the replay input. The name is based on the folder used for the replay setup meaning whenever a setup is changed one would have to redefine all the related buttons. Yes one can rename the input but the foldername is a good indication about the specific production at the time.
Maybe change the input Selection to "Replay" or none at all as there is only one replay setup possible anyways (type="Replay" instead of shortTitle="******").
The buttons excecute the commands with no input specified, but then the tallys dont currently
Tnx
Doggy
#976 Posted : Monday, June 3, 2024 7:48:50 PM(UTC)
Something i noticed:
- password protected template from previous version says "wrong password", had to revert to previous to save template without PW first
- On onelaptop i have a choise between "Replay" and the name of the replay input (without the A or B adition) while on another it give me the option of selecting input named and one with the B named input (no "Replay" only option). either wayonly one of them will respond with a tally (see also comment in my previous post regarding input selection)
raugert
#977 Posted : Tuesday, June 4, 2024 10:31:22 PM(UTC)
raugert
Canada
Thanks for the feedback Doggy. I will look into these issues.
#978 Posted: : Tuesday, June 11, 2024 1:04:33 AM(UTC)
Italy
Thank you very much Rougert for the additional function that saves the zoom factor. Seems like a small thing but is great for usability!!!
One question: You have also added the latest shortcuts, unfortunately I can't find the shortcut “SwapLayerAnimated” did you not add it or do I have tomatoes on my eyes?
raugert
#979 Posted : Tuesday, June 11, 2024 5:31:36 AM(UTC)
raugert
Canada
Thanks for heads up. It appears that I may have missed that one. I’ll add it to the next update.
Richard
barryondeck
#980 Posted : Wednesday, June 19, 2024 4:06:59 AM(UTC)
barryondeck
Is it possible to change the text of a title within a panel on the iPad?
I feel like I did this once but I may have been drunk so I might be wrong.
Here's the scenario I'm trying to accomplish:
When I have a guest on my show, sometimes I forget to change the pre-built lower third where I put my guest's name.
(sometimes it will have last week's guest's name).
Right now I just right click the input and change it but as I'm slowly moving to running my show from my ipad using Panel Builder Controller I was wondering if this is possible.
Thanks.
Guest (10)
