Joined: 2/23/2019(UTC) Posts: 138  Thanks: 19 times Was thanked: 29 time(s) in 26 post(s)
EDIT: fixed in 27.0.0.75. Thank you Martin. -- I've found that when exporting a replay event to mp4 the audio stream is around 100ms shorter than the video. (this is on a 30fps project, it may be different on others) Exporting an 8 second event and inspecting the file with MediaInfo shows the video stream as 8000ms and the video as 7893ms. Using ffprobe -show_entries stream=duration returns 7.999967s for video and 7.893312 for audio. Loading it into Resolve also shows the silence for around the last 3 frames. When exporting multiple events as one file there is only one dropout at the end. i.e. exporting 4x 5 second events individual gives 115ms of missing audio on each clip. Exporting them as one file includes the missing audio on the first three clips but the final one misses 96ms. I'm writing automation for processing exported replay events into social media clips using ffmpeg and this track length mismatch means joining clips together results in audio dropouts near the join. I've just found this post that makes it sound like this appeared in v26. The suggested fix of going to 4 channel audio makes no difference for me, and using vMix AVI reduces the gap to 30-40ms, but then can't be used with ffmpeg. It would be really helpful if this could be looked at. Thank you.
Joined: 11/15/2021(UTC) Posts: 87  Thanks: 8 times Was thanked: 12 time(s) in 10 post(s)
I noticed that inserting inputs via drag&drop (for example a .png-File) has recently stopped working. Can someone double check that?
Rank: Staff
Groups: Registered, Administrators Joined: 12/13/2012(UTC) Posts: 243 Location: Gold Coast, Australia
Thanks: 7 times Was thanked: 159 time(s) in 72 post(s)
Originally Posted by: Salvatore  I noticed that inserting inputs via drag&drop (for example a .png-File) has recently stopped working. Can someone double check that? Looks to be working fine. Could you send through an email to our Support Team if you're still having issues.
Since installing vMix 27.0.0.69 I can no longer connect my Sony ZV-10 via Cam Link. Windows had two updates on 15th May. I uninstalled both of them to ensure that they were not causing the issue. HELP! PLEASE!
I am open to any suggestions.
Joined: 5/22/2024(UTC) Posts: 1  Location: quebec Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: admin  Hi all,
There is now some preliminary support for Zoom Webinars in vMix as of 27.0.0.64 This required a fair amount of work behind the scenes to optimise for the extremely large number of attendees that these webinars can attract.
There are also a couple of requirements that need to be met in order for it to work:
1. The Webinar must be a standard Zoom Meetings webinar. Events require different login methods and are not currently supported as a result. 2. The Zoom participant must be promoted by the Zoom host to Panelist. vMix will appear to be stuck on "connecting.." until the promotion occurs.
We are interested in feedback on how this functionality works in practise, as it is naturally very hard for us to test meetings with large numbers of participants!
Martin vMix I've tried the zoom plug in with webinars, and in practice session, everything worked great with panelists. then when we started the webinars, and 450+ people joined, the plug in was trying to populate the list of available sources and made vmix crashed.. as we started the event. is there an option to ONLY have the panelists available and bot the participants? thanks!
 1 user thanked PïerreG for this useful post.
Is maybe the audio level sent from vMix (27.0.0.75, latest plugin) to the Zoom Meetings too low? We sometimes get comments from Zoom participants that our (the vMix participant) audio is too low. After some experiments* it turns out that if "Original sound for musicians" is disabled the audio level becomes fine. I suspect that the audio level in this case is automatically adjusted by the Zoom SDK between vMix and Zoom's server. A strong clue in that direction is that when we used to feed a Zoom/Rooms app with NDI audio from vMix, we had to gain it with 18 dB in the NDI Webcam tool for Zoom to be happy (so to speak). This means that we currently dare not use "Original sound for musicians". We can not gain the audio bus sent to Zoom, as that will distort the audio. Compare "The audio levels from vMix may appear 20dB lower than expected in some applications". If this is the case here, I am not sure a similar option for Zoom setup is the way to go. The only receiver is the Zoom plugin, and it will always benefit from a correct level limited by vMix. *The fact that each Zoom Input still has an individual setting for "Original sound for musicians" made me unsure of if it was enabled or not. The only way to find out was to listen as another participant in the Zoom meeting and notice when vMix's audio was low or fine. Side note, https://www.vmix.com/hel...ZoomMeetingSettings.html does not cover the new "Unmute/mute" self.
Hello, I am using vMix very well here in Korea.
I think the Zoom feature included in vMix 27 is amazing.
I am testing various scenarios to use it during broadcasts, and I really appreciate that I can receive audio and video signals separately for each presenter.
However, when using the interpretation feature in Zoom, the audio signals do not come in separately.
If this part could be improved, it would be great if we could receive individual audio signals even if the presenter is designated as an interpreter.
Looking forward to a positive update!
I am always using vMix well. Thank you:)
Hi, JL Cooper SloMo Pro does not work with version 27. Drops connections, behaves strange. Really messed up. Roll back to v26 and all is good.
Originally Posted by: richardgatarski  Is maybe the audio level sent from vMix (27.0.0.75, latest plugin) to the Zoom Meetings too low? We sometimes get comments from Zoom participants that our (the vMix participant) audio is too low. After some experiments* it turns out that if "Original sound for musicians" is disabled the audio level becomes fine. I suspect that the audio level in this case is automatically adjusted by the Zoom SDK between vMix and Zoom's server. A strong clue in that direction is that when we used to feed a Zoom/Rooms app with NDI audio from vMix, we had to gain it with 18 dB in the NDI Webcam tool for Zoom to be happy (so to speak). This means that we currently dare not use "Original sound for musicians". We can not gain the audio bus sent to Zoom, as that will distort the audio. Compare "The audio levels from vMix may appear 20dB lower than expected in some applications". If this is the case here, I am not sure a similar option for Zoom setup is the way to go. The only receiver is the Zoom plugin, and it will always benefit from a correct level limited by vMix. *The fact that each Zoom Input still has an individual setting for "Original sound for musicians" made me unsure of if it was enabled or not. The only way to find out was to listen as another participant in the Zoom meeting and notice when vMix's audio was low or fine. Side note, https://www.vmix.com/hel...ZoomMeetingSettings.html does not cover the new "Unmute/mute" self. OK, after further experiments think I've figured out what is causing my problem. We are sending BusE to Zoom, and vMix seems to ignore all Audio settings for the audio busses sent to Zoom (and Calls). In our case, most importantly, the Gain is ignored. But also Plugins, EQ, Compressor and Noise gate. Background: When we started to use vMix Call (years ago) we noticed that in many cases the audio level from callers sometimes came in too low. This was because the callers did not set their mike levels properly. In order to be able to use the Call Input's audio mixer fader to increase the volume above the level we got, we typically gain the Call Input's audio by 18 dB, and compensate by setting the fader for that Input to -18 dB (compare gain staging in audio consoles). Later we also did a similar thing for audio buses sent out (e.g. via NDI to a conference overflow room). Without thinking, I did the same thing for the audio bus sent to Zoom (and Calls). Result: If I set BusE gain level to 18 dB, and lower BusE's fader to -18, and use BusE as audio source to Zoom, AND have "Original sound for musicians On" then the participants in Zoom will hear vMix much lower than the other participants. If I turn "Original sound..." off, Zoom will autogain the level and vMix can be heard much better. Note1: The Audio bus level meter shows what I expect, not what is sent to Zoom/Calls. Note2: When an Audio bus is sent out via NDI, all Audio settings are applied by vMix. I did also check for Calls and it turned out that for these Inputs too, the Audio bus's settings are ignored. Fix: No gain on the Audio Bus, max it's fader level, turn "Original sound" on, then it sound good in Zoom (and Calls). Tentatively I think that here the gain issue is of no importance to us (at least in our setups so far), as we must always make sure that everything we sent to that bus should be at the desired level. Not needing any gain or other adjustments. Question: Is this a bug, or something that cannot be fixed (a.k.a "by design" ;).
Joined: 2/7/2024(UTC) Posts: 192  Thanks: 13 times Was thanked: 7 time(s) in 6 post(s)
Originally Posted by: richardgatarski  Originally Posted by: richardgatarski  Is maybe the audio level sent from vMix (27.0.0.75, latest plugin) to the Zoom Meetings too low? We sometimes get comments from Zoom participants that our (the vMix participant) audio is too low. After some experiments* it turns out that if "Original sound for musicians" is disabled the audio level becomes fine. I suspect that the audio level in this case is automatically adjusted by the Zoom SDK between vMix and Zoom's server. A strong clue in that direction is that when we used to feed a Zoom/Rooms app with NDI audio from vMix, we had to gain it with 18 dB in the NDI Webcam tool for Zoom to be happy (so to speak). This means that we currently dare not use "Original sound for musicians". We can not gain the audio bus sent to Zoom, as that will distort the audio. Compare "The audio levels from vMix may appear 20dB lower than expected in some applications". If this is the case here, I am not sure a similar option for Zoom setup is the way to go. The only receiver is the Zoom plugin, and it will always benefit from a correct level limited by vMix. *The fact that each Zoom Input still has an individual setting for "Original sound for musicians" made me unsure of if it was enabled or not. The only way to find out was to listen as another participant in the Zoom meeting and notice when vMix's audio was low or fine. Side note, https://www.vmix.com/hel...ZoomMeetingSettings.html does not cover the new "Unmute/mute" self. OK, after further experiments think I've figured out what is causing my problem. We are sending BusE to Zoom, and vMix seems to ignore all Audio settings for the audio busses sent to Zoom (and Calls). In our case, most importantly, the Gain is ignored. But also Plugins, EQ, Compressor and Noise gate. Background: When we started to use vMix Call (years ago) we noticed that in many cases the audio level from callers sometimes came in too low. This was because the callers did not set their mike levels properly. In order to be able to use the Call Input's audio mixer fader to increase the volume above the level we got, we typically gain the Call Input's audio by 18 dB, and compensate by setting the fader for that Input to -18 dB (compare gain staging in audio consoles). Later we also did a similar thing for audio buses sent out (e.g. via NDI to a conference overflow room). Without thinking, I did the same thing for the audio bus sent to Zoom (and Calls). Result: If I set BusE gain level to 18 dB, and lower BusE's fader to -18, and use BusE as audio source to Zoom, AND have "Original sound for musicians On" then the participants in Zoom will hear vMix much lower than the other participants. If I turn "Original sound..." off, Zoom will autogain the level and vMix can be heard much better. Note1: The Audio bus level meter shows what I expect, not what is sent to Zoom/Calls. Note2: When an Audio bus is sent out via NDI, all Audio settings are applied by vMix. I did also check for Calls and it turned out that for these Inputs too, the Audio bus's settings are ignored. Fix: No gain on the Audio Bus, max it's fader level, turn "Original sound" on, then it sound good in Zoom (and Calls). Tentatively I think that here the gain issue is of no importance to us (at least in our setups so far), as we must always make sure that everything we sent to that bus should be at the desired level. Not needing any gain or other adjustments. Question: Is this a bug, or something that cannot be fixed (a.k.a "by design" ;). I've never used vMix Call, but the vMix Zoom plugin works very well. I'm currently sending using the "Original sound for musicians" setting turned on and all of my videos, music, and sound effects have no issue making it into Zoom and the level is easily adjusted on a bus or on the individual inputs.
HI Martin,
Going back to Zoom webinars, is there currently a way to see Panellists only?, rather than everyone either side of the fence?? Had 600+ in a webinar over the last few days, it was impossible to add them to an input with the list jumping around. The right click Participant source doesn't hold enough in the list to select from there.
Workaround was to add as input, then add that to a layer in a 6up..time consuming in a quickfire AGm type situation with a host picking hands at random. Day 2, we only had ninety..so most i could get via add source.. This time I had a second machine where I could pin anyone whom was't appearing in the drop down.
Loving the zoom update by the way, it works pretty well and has been 100% reliable and easy to work with.
Many thanks John
Joined: 2/23/2023(UTC) Posts: 80  Thanks: 26 times Was thanked: 19 time(s) in 5 post(s)
Bug report vMix 27.0.0.83. Steps to reproduce:
- Create new title input
- Type the text Q&A
- Click the + button to add it as a preset
- Close the title edit window
- Right click on the title input
- Note the Q&A title is rendered as QA
Title presets should be escaped so & characters do not turn on Windows menu acceleration.
- Open Streaming Settings window
- Under the Destination drop down, select Custom RTMP server
- Click Advanced
- Note how the Advanced Window is not match the vMix theme
Other windows that is also missing the theme are under: PlayList > New PlayListMultiCorder > AVI > Codec settings (when vMix Video Codec is selected) Recording > AVI > Codec settings (when vMix Video Codec is selected) vMix Diagnostics
- Create Shortcut (doesn't matter which key) that triggers the ResetInput function
- Open any of the vMix windows (e.g. Overlays, Statistics, Shortcuts)
- Trigger the ResetInput shortcut (can also be done via the API)
- Note how the window opened in the previous step is closed
- Open Overlay Settings window
- Set Type of overlay to PictureInPicture
- Under Border, double click on the color picker
- Note how the standard windows color picker is opened
Expected the vMix color picker that allows setting color by hex value.
ZOOM question:
Is there away to get GRID VIEW of ZOOM Meeting into vMix 27 without using Desktop Capture?
Want to be able to, sometimes show all ZOOM Meeting participant on the screen while in grid view. Is this possible or not?
Originally Posted by: ovonder  During upgrade from .55 i get a blocking error
c:\program files (x86)\vmix\vcmwrapper.dll access is denied.
I was running vmix .55 pressed check for update and installed update while vmix was still running. Even after i closed vmix and tried retry, it did not work.
I had to abort then i installed from \documents, but ran into the same warning.
I get this a lot when I update vMix. My workaround is to open a command line as an admin, then rename the offending file to *.bak (EG ren vcmwrapper.dll vcwrapper.bak) then choose "Try again".
