Instant Replay
v26; replay export misses last ~half second of audio when exporting 2 channels
Thanks: 179 times Was thanked: 20 time(s) in 17 post(s)
Can anyone reproduce this? vMix Pro, v26.0.0.40, when exporting one or multiple replay events and choosing in the export dialog: Audio Channels: 2, the final ~ half second of audio is missing (video is complete). When choosing Audio Channels: 4, the audio and video are both complete. Exporting to vMix AVI.
Workaround then seems to be: always choose 4 channels (even if you have only 2). Hopefully the 2 channel export can be looked into and fixed if needed.
EDIT: in v25, this issue seems absent. Maybe adding the choice (in v26) between 2 and 4 audio channels in IRP export, broke something.
Wondering if others also have this issue; on the latest v26 release it still persists: when exporting replay events, the last ~half second of audio is not present in the exported .avi file.
This is independent of type of PC, method of capture. I have experienced it on several PC's and on both NDI and capture card inputs.
Kind thanks for any ideas.
Cheers from Arie
Instant Replay
