Ario
#1 Posted : Monday, April 3, 2023 3:50:02 AM(UTC)
Ario
Was thanked: 20 time(s) in 17 post(s)
Can anyone reproduce this?
vMix Pro, v26.0.0.40,
when exporting one or multiple replay events and choosing in the export dialog: Audio Channels: 2,
the final ~ half second of audio is missing (video is complete).
When choosing Audio Channels: 4,
the audio and video are both complete.
Exporting to vMix AVI.
Workaround then seems to be: always choose 4 channels (even if you have only 2).
Hopefully the 2 channel export can be looked into and fixed if needed.
EDIT: in v25, this issue seems absent.
Maybe adding the choice (in v26) between 2 and 4 audio channels in IRP export, broke something.
Ario
#2 Posted : Friday, November 17, 2023 2:47:59 AM(UTC)
Ario
Wondering if others also have this issue;
on the latest v26 release it still persists:
when exporting replay events, the last ~half second of audio is not present in the exported .avi file.
This is independent of type of PC, method of capture.
I have experienced it on several PC's
and on both NDI and capture card inputs.
Kind thanks for any ideas.
Cheers from
Arie
