GUI
Luis70
#1 Posted : Monday, December 25, 2023 5:09:22 PM(UTC)
Luis70
Grenada
Was thanked: 11 time(s) in 11 post(s)
Is there a way to place all my inputs on a sperate monitor?...I am asking this because I have over 30 inputs and I would like to see them all so I can make quick selections, and not having to go through scrolling up and down to find what I need
Roy Sinclair
#2 Posted : Thursday, January 11, 2024 8:11:49 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
All of them active at the same time?
There is no way to break out the mini-screens to another monitor though it is in the feature requests (not saying they'll ever do it).
For now though have you tried these workarounds?
If the input isn't going to be used in the current production Left-click on it's title to shrink it to a small column. Shrinking unused inputs allows other inputs that were off-screen to be pulled on-screen.
You can also set the size of each input on Display tab of the vMix Settings, it's the "Input Size" option. There you can make the size of each input smaller which will also allow more of them to visible at the same time.
Salvatore
#3 Posted : Thursday, January 11, 2024 10:36:52 AM(UTC)
Salvatore
Italy
Was thanked: 12 time(s) in 10 post(s)
You can add an Multiview to another Multiview (Layer)
Look at (06:50)
Luis70
#4 Posted : Thursday, January 11, 2024 12:47:42 PM(UTC)
Luis70
Grenada
You don't seem to understand what I was asking, but anyway, I know how to adjust the input screens ..I was using vMix from the year it was launched....I actually teach friends how to setup and use vMix....The only thing I don't know about vMix is how to rewrite it, or edit the GUI to my likings....and if I could, I would create my own GUI.....I use vMix almost every day...live streaming, closed-circuit,(especially during election campaigns for wide screen.....was the first person using vMix for this in my country) or just mixing videos and record for later posting....all I was hoping that someone has a script that can place the inputs on another scree for quick view....May have to ask John Mahoney from Streaming Alchemy....he may be able to help me.
Salvatore
#5 Posted : Thursday, January 11, 2024 4:38:32 PM(UTC)
Salvatore
Italy
Depending on the hardware used, you can use Output 2,3,4 or Display 2,3 for additional image output and connect another screen via SDI, NDI or HDMI. You don't need a script for this. You can switch through the inputs with shortcuts.
There is no preselection of inputs (for example by right-clicking on the input to add this input to a multiview. )
At best, you could enter the input numbers that should be visible on your multiview to the dynamic value and use a Script to Show them. But then you can do that straight away by Insert inputs via the layers to a multiview.
Or what Roy meant you can use the category function to sort inputs
https://www.vmix.com/help26/Categories.html
nikosman88
#6 Posted : Friday, January 12, 2024 4:50:34 AM(UTC)
nikosman88
Greece
Hello. A workaround to do this is by using web controller and shortcuts by changing the display in shortcut from default to thumbnail. The up-coming v27 version is support live preview of any input in low res but you can see them in your pc mon. So a way to see all the inputs is to make shortcuts (that will do something to this input that you need for example cut or fade) and see the inputs at 127.0.0.1:8088 in your pc monitor like the way we see them at elgato streamdeck
Similar Topics
Shortcut Assignment WEB GUI (Feature Requests)
by DJShaggyd 5/16/2026 7:02:14 PM(UTC)
Most efficient way to get GUID of active source in XML, in scripting (General Discussion)
by fgolman 3/27/2026 10:02:30 AM(UTC)
OMT integration in settings GUI (Beta Discussion)
by pm 8/25/2025 1:06:02 AM(UTC)
confused with the gui (Beta Discussion)
by dark_ata 8/23/2025 2:47:38 AM(UTC)
Title GUI improvement (Feature Requests)
by marton 7/4/2025 10:52:19 PM(UTC)
GUID questions (General Discussion)
by fgolman 4/3/2025 6:12:36 PM(UTC)
Main GUI - Removable program and preview (Feature Requests)
by Claude Beaulé 12/2/2024 9:23:53 AM(UTC)
EPG - Electronic Program Guide (Feature Requests)
by afrojuju 1/28/2024 12:42:50 PM(UTC)
Error with Pan Position Geometry GUI (General Discussion)
by Lastmarine 1/8/2024 1:17:46 AM(UTC)
vMix 26 Help Guide NVIDIA Update (General Discussion)
by haloflyer 4/4/2023 2:29:09 AM(UTC)
Possible to autostart VST3 GUI? (General Discussion)
by svenito 9/4/2022 6:09:15 PM(UTC)
Audio section GUI useability improvements (Feature Requests)
by TBacker 2/2/2022 12:19:32 AM(UTC)
Render time increase when GUI is in focus (General Discussion)
by FrankLeggett 11/19/2021 12:17:56 AM(UTC)
Remove VST GUI requirement (Feature Requests)
by Alex Bakhrushin 6/18/2021 9:02:13 PM(UTC)
Assign inputs by unique ID (GUID) (Feature Requests)
by fwieland 6/17/2021 6:36:16 PM(UTC)
Looking for guidance (General Discussion)
by ocrtalk 2/5/2021 6:08:09 AM(UTC)
Vmix call GUI error! (vMix Call)
by jcw718 12/5/2020 9:35:42 AM(UTC)
Audio Mixer GUI update (Feature Requests)
by sinc747 5/9/2020 8:14:42 AM(UTC)
Help Guide 23... (Feature Requests)
by nickyg 4/28/2020 6:09:58 AM(UTC)
SRT Deployment Guide (SRT)
by admin 10/26/2019 8:23:26 PM(UTC)
Positioning + Guides + Optional Snap feature (Feature Requests)
by Podcast Bob 10/16/2019 8:40:18 PM(UTC)
Is there any comprehensive scripting guide? (General Discussion)
by s0bari 6/23/2019 1:21:15 PM(UTC)
Guidance on the best equipment for Esports productions (General Discussion)
by R_L 10/23/2018 7:19:32 AM(UTC)
XML for EPG (TV Guide) in Data source (General Discussion)
by palco5 9/30/2018 2:05:04 AM(UTC)
Scripting in vMix Reference Guide (General Discussion)
by rjmurdock 2/27/2018 12:49:41 PM(UTC)
super new to vMix. looking for some guidance. (General Discussion)
by iamralphsutton 8/14/2016 12:28:22 AM(UTC)
NDI vMix Gui Capture (NDI)
by madness 6/6/2016 1:10:02 PM(UTC)
Where does the GUID come from to use in API command (General Discussion)
by tdurhamjr 2/26/2015 11:48:06 PM(UTC)
API Specify InputName in addition to Input Number and GUID (Feature Requests)
by richardgatarski 11/29/2014 4:45:00 AM(UTC)
mic'ing a guitar amp? (General Discussion)
by luthierwnc 11/28/2014 5:07:26 PM(UTC)
