10 Pages«<56789>»
ClementN
#121 Posted : Monday, July 7, 2014 6:27:00 PM(UTC)
ClementN
Romania
richardgatarski wrote:
Been a dare devil this week and used v13.0.0.104 in a few real productions last week. On mistake we made many times was to start External instead of Streamer. I suggest that the buttons (bottom part of main window) would rather be labeled as:
[Setup][RECORD], [Setup][EXTERNAL], [Setup][STREAM]
(where former buttons Start is RECORD, EXTERNAL, STREAM)
Anything helps to avoid confusions and mistakes during live production has my vote .. :)
#122 Posted : Tuesday, July 8, 2014 7:46:25 AM(UTC)
Was thanked: 4734 time(s) in 1624 post(s)
vMix Preview 13.0.0.125 is now available for download
http://www.vmix.com.au/download/vmix13preview.exe
This is a release candidate which means we are only a few days away from the final release.
Changes/Fixes
* A cog icon has been added to the Output preview bar which allows users to switch
to previewing the Recording and External Outputs if they have a different output or overlay setup configured.
* Fixed REC/EXT/STREAM icons underneath Output preview.
These provide an at a glance notification of what is currently running and should help
with problems of forgetting to click start, or starting the wrong output.
* Some fixes to PlayList including preserving items in the PlayList when they are re-configured.
* PlayList can be run in Manual Mode which allows users to cycle through each item manually by clicking Next.
* Additional audio smoothing added to reduce clicks and pops when the audio source drops samples.
* Fixed MP4 recording not working with Audio unticked
* Added orange Solo icon underneath Output preview when Solo is in use.
* Fixed Stop streaming working even if locked
* Installer includes a demo UV map virtual set provided by http://www.virtualsetworks.com/
thanks 6 users thanked admin for this useful post.
TVIason on 7/8/2014(UTC), pasingshot on 7/8/2014(UTC), doggy on 7/8/2014(UTC), ClementN on 7/8/2014(UTC), cbcal on 7/8/2014(UTC), madness on 7/8/2014(UTC)
ClementN
#123 Posted : Tuesday, July 8, 2014 1:38:06 PM(UTC)
ClementN
Romania
Hello Martin,
I am not sure if this is a .125 behavior or it was the same in the previous versions.
When an input is "Solo" selected that de-select any other "Solo".
The hardware solution (audio mixers) allow multiple channels to be selected as "solo".
Is this the way you wanted to be, Martin ?
cutter07
#124 Posted : Tuesday, July 8, 2014 2:27:16 PM(UTC)
cutter07
I think the lock button should only prevent clicking a button by mistake and not when a trigger is set in an input e.g. to stop recording.
richardgatarski
#125 Posted : Tuesday, July 8, 2014 3:35:01 PM(UTC)
richardgatarski
I really appreciate the import/export Title presets, and the added warning when Clear is clicked.
Also noticed that the .csv file needs to be in utf-8 for national characters to work (please consider making a note about that in the help file).
What about my proposal to change the "Cut" button on Inputs to "Preview" (or "Prvw") if the right-click has been set to anything else than Cut? As it is now there is no way to Preview that input, unless right-click is changed back.
Maybe this should be supplemented by spelling out what is actually previewed (eg "External 1").
I strongly believe this is not sufficient, perhaps even worse from a UX perspective. Clicking a button labelled "Start", seeing it turn green and checking that another "icon" shows the text "STREAM" in red confuses even the most relaxed person. Not to mention anyone operating a complex vMix setting in a hectic environment.
vMix is by definition (extremely high functionality) a complex application. Having two different (looking) indicators showing the same thing does not seem to me as a good idea. I am equally reluctant to having a button labeled "Recording" actually meaning "Setup recording".
Just my thoughts, open for alternative minds :)
ngtech
#126 Posted : Tuesday, July 8, 2014 9:27:55 PM(UTC)
ngtech
Martin thanks for this great program, Vmix is so far the best video mixing software I have ever seen, I been using this program for a while and the support you provide is excellent, you really listen to your costumers, I been testing ver. 13 so far everything look, and runs great, thanks for the excellent support that you provide to us.
#127 Posted : Wednesday, July 9, 2014 1:14:20 AM(UTC)
The labelling of the buttons has a lot to do with being able to fit them
all on a display that for many users is only 1280 pixels wide.
Perhaps as a compromise, I can set both the Recording/Streaming/External and Start/Stop buttons to turn red
when running to match the colour of the indicator icons.
gregboy12
#128 Posted : Wednesday, July 9, 2014 10:28:39 AM(UTC)
gregboy12
Views messages in topic : 16
admin wrote:
New and perhaps final Beta update of vMix 13 is now available (13.0.0.117)
Changes and fixes:
* Added support for Elgato Game Capture and LGP Stream Engine
Users should be aware these devices add a significant delay.
* Improved MultiCorder recordings with support for most capture cards
* Ability to create new recording every x minutes now available for all formats
including MultiCorder. Great for AVI and MP4 which are difficult to recover if power is lost.
* Made clear in Basic / Basic HD that List is not available. Also
disabled 2,3,4 overlay buttons in these editions.
* Fixed up some issues when resetting settings to default
* Fixed video playback issues
* Fixed issues with Solo button when adding and removing inputs
* Fixed issues with List input with new audio engine
* New REC, EXT and STREAM notification icons underneath Output preview.
* Audio busses can not be changed when in Lock mode.
* Clarified naming of Audio Outputs and added None option
* Fixed Saturation not saving on systems other than English
Please report any bugs and issues. If all goes well the final release will be out soon.
Hi Martin
Ive downloaded this version, opened the program, went to input, selected camera and looked from the drop down menu for the Elgato Game Capture that i have but it isnt there my device is plugged all ready and setup correctly but i cant find it on the vmix program, Any help would be great
EDIT: Scratch that, ive found it, for anyone having trouble then you can only use it with the non-x64 version
richardgatarski
#129 Posted : Wednesday, July 9, 2014 3:08:23 PM(UTC)
richardgatarski
How about using the cog wheel icon (below "[C]") to replace "Setup". Takes less space, and gives bottom row:
[C][Record], [C][External], [C][Stream], [C][PlayList], [C][MultiCorder]
This would follow the convention for most other elements of the main window. That is, cog wheels are used for setting things up and text buttons act/start (eg Fullscren or Cut). "Overlay" could perhaps be changed to an icon instead of a text button.
I kind of like the visual indicators under Output for REC/EXT/STREAM, but please keep them in that order as this is what they eye expects from the button's order. Now the are ordered after when the corresponding function is started.
Matching color (red OR green) is definitely best. Then it is an open question if they should be green or red. People used to (live) video production/switching might consider red to be the right choice. On the other hand red is a warning signal, logical for "On air" but not for something indicating "this thing is good". Personally I would prefer green, but I guess most other users would vote for red - so go for red.
ClementN
#130 Posted : Wednesday, July 9, 2014 6:33:25 PM(UTC)
ClementN
Romania
I vote for all those ideas! 100%
#131 Posted : Thursday, July 10, 2014 2:50:43 AM(UTC)
Like this?
I was hesitant to make these changes this close to release, but if
everybody is in agreement that this makes things easier, better now than later.
ClementN on 7/10/2014(UTC)
ovinas
#132 Posted : Thursday, July 10, 2014 4:09:22 AM(UTC)
ovinas
Thumbs up. Waiting for the updated preview version.....
Bardos59
#133 Posted : Thursday, July 10, 2014 4:37:45 AM(UTC)
Rank: Guest
Groups:
Great, now my friend can not mistake external for record , unless he has a vision problem....
Great work Martin
ask
#134 Posted : Thursday, July 10, 2014 4:43:04 AM(UTC)
ask
That looks more efficient use of the space. +1
pasingshot
#135 Posted : Thursday, July 10, 2014 4:44:34 AM(UTC)
pasingshot
yeah! for me is more useful!
richardgatarski
#136 Posted : Thursday, July 10, 2014 7:25:47 AM(UTC)
richardgatarski
Whow, even better than I imagined. Thank you Martin!
richardgatarski
#137 Posted : Thursday, July 10, 2014 7:33:26 AM(UTC)
richardgatarski
admin wrote:
vMix 13 Preview (13.0.0.90 Beta) is here!
* Custom Mouse Click action can be set in Input Settings
Does no one except me need to preview Inputs that has Click action set to anything else than Cut?
Please forgive me for bumping this again, but no one has commented my suggestion to replace the "Cut" button in Inputs with "Prvw" if the click action is changed.
v13 is soon to be released, many users have asked for alternative click actions and I am afraid that they will really miss the possibility to preview.
#138 Posted : Thursday, July 10, 2014 10:13:41 AM(UTC)
vMix 13 Preview 13.0.0.130 can now be downloaded
This includes the new bottom row button layout and some other small fixes.
richardgatarski on 7/10/2014(UTC), madness on 7/10/2014(UTC)
Maximus
#139 Posted : Thursday, July 10, 2014 10:30:38 AM(UTC)
Maximus
I typically set up shortcut keys for Preview, so at this point I would rather have the cut button remain. In the absence of shortcut keys assigned to preview inputs, your request would make sense. I however prefer to always have s cut function available directly from an input.
My 2 cents
rrpro
#140 Posted : Thursday, July 10, 2014 10:56:01 AM(UTC)
rrpro
Great visual change! Keep that bottom (in my opinion) :P
Guest (7)
Similar Topics
vMix 13 preview Shortcut key issue (General Discussion)
by IceStream 6/18/2014 7:05:42 PM(UTC)
10 Pages«<56789>»
