i'm using VMIX 23. I can use the vmix countdown feature to trigger my next input with OnCountdownCompletion. But it requires me to manually calculate and enter the remaining minutes/seconds. I would rather countdown to a specific time-of-day to trigger my next input. I can display a countdown to 3pm using this: {0:3:00 PM|HH:mm:ss}. But, the vmix countdown feature ignores this altogether. When this countdown ends, nothing happens; I just get zeros displayed on the screen. The OnCountdownCompletion trigger does not happen. The OnCompletion trigger does not happen.
Is there a way I can use {0:3:00 PM|HH:mm:ss} with the vmix countdown feature?
Originally Posted by: cfweeks  i'm using VMIX 23. I can use the vmix countdown feature to trigger my next input with OnCountdownCompletion. But it requires me to manually calculate and enter the remaining minutes/seconds. I would rather countdown to a specific time-of-day to trigger my next input. I can display a countdown to 3pm using this: {0:3:00 PM|HH:mm:ss}. But, the vmix countdown feature ignores this altogether. When this countdown ends, nothing happens; I just get zeros displayed on the screen. The OnCountdownCompletion trigger does not happen. The OnCompletion trigger does not happen.
Countdown to time is part of the clocks as such not a countdown that can be triggered. A (vb.net) script could achieve your goal (comparing date/time) or even check the duration left of a playing input BTW Wwy still on V23?
