Joined: 6/24/2024(UTC) Posts: 11  Location: Missouri Was thanked: 1 time(s) in 1 post(s)
I have been using the countdown timer for over a year without problems starting from the title editor. I attempted to assign "StartCountdown" to the "T" key but it does not start the countdown timer.
Am I miss interpreting something? The other keyboard shortcuts I have assigned work correctly.
Thanks!
Joined: 7/4/2021(UTC) Posts: 424  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Originally Posted by: John Hopkins  I attempted to assign "StartCountdown" to the "T" key but it does not start the countdown timer. I just tried it on my end (vMix 28)--no issues. Do you have it mapped to the correct title input and text field?
I went to: Settings --> Shortcuts --> Add --> "T" --> - Function = StartCountDown - Input = 7 Count Down Timer - "Assign Shortcut to Input Number" - Tried it both with an without the box checked - Title = Timer.Text - Title = Start CD - Description1 = Start Countdown - Description2 = - Display = Default - Local Shortcut - Left unchecked - Show in Web Controller - Checked
Walt, Thanks for responding, I reviewed it and had the first "Title" box Blank. I clicked the down arrow and selected the only option "Timer.Text" and it started working.
John
