John Hopkins
#1 Posted : Sunday, February 9, 2025 11:49:11 AM(UTC)
John Hopkins
I have been using the countdown timer for over a year without problems starting from the title editor.
I attempted to assign "StartCountdown" to the "T" key but it does not start the countdown timer.
Am I miss interpreting something? The other keyboard shortcuts I have assigned work correctly.
Thanks!
WaltG12
#2 Posted : Tuesday, February 11, 2025 1:23:31 PM(UTC)
WaltG12
I just tried it on my end (vMix 28)--no issues.
Do you have it mapped to the correct title input and text field?
John Hopkins
#3 Posted : Wednesday, February 12, 2025 3:36:42 AM(UTC)
John Hopkins
I went to: Settings --> Shortcuts --> Add --> "T" -->
- Function = StartCountDown
- Input = 7 Count Down Timer
- "Assign Shortcut to Input Number" - Tried it both with an without the box checked
- Title = Timer.Text
- Title = Start CD
- Description1 = Start Countdown
- Description2 =
- Display = Default
- Local Shortcut - Left unchecked
- Show in Web Controller - Checked
Walt, Thanks for responding, I reviewed it and had the first "Title" box Blank.
I clicked the down arrow and selected the only option "Timer.Text" and it started working.
John
Guest (4)
