10 Pages<12345>»
richardgatarski
#41 Posted: : Thursday, June 19, 2014 1:52:02 PM(UTC)
richardgatarski
Martin,
When using v13 I frequently set 50i instead of 50p as I add new camera inputs.
In v12 the order for frame rate settings is:
50i or 25p
50p
and so on...
In v13 there is a sligt change, namely
50i
25p
50p
and so on...
At least for my sore eyes it is very easy to ignore the little "i". May I humbly suggest:
25p
50i
50p
(It would probably to go far and use 25 progressive, 50 interlaced, 50 progressive altough more distinguishable)
Thanks.
GBIM
#42 Posted : Thursday, June 19, 2014 10:59:43 PM(UTC)
GBIM
Hello Martin, can you please consider this post http://forums.vmix.com.a....aspx?g=posts&t=2296 included in Vmix 13 final.
Regards
GBIM
thanks 1 user thanked GBIM for this useful post.
krassesPferd on 6/20/2014(UTC)
GBIM
#43 Posted : Thursday, June 19, 2014 11:04:12 PM(UTC)
GBIM
Hello Martin, Why are we not getting any reply on uv mapping reflection demo? or Is it not included in the Vmix 13 Preview Version Yet?
#44 Posted : Thursday, June 19, 2014 11:20:26 PM(UTC)
Was thanked: 4711 time(s) in 1615 post(s)
UV mapping works, there just isn't a demo set available yet.
You can purchase a set from http://www.virtualsetworks.com and request it in vMix format which includes UV mapping/reflections if you like.
gregboy12
#45 Posted : Friday, June 20, 2014 11:48:27 AM(UTC)
gregboy12
Any news or a list on what capture cards are going to be compatible with vmix 13?
nandhitv
#46 Posted : Friday, June 20, 2014 4:35:51 PM(UTC)
nandhitv
Please make one simple set for demo. we will learn from it
#47 Posted : Saturday, June 21, 2014 7:17:10 AM(UTC)
A set using UV mapping and reflections can be downloaded below:
http://www.vmix.com.au/download/studio147_a_wide.zip
TVIason on 6/21/2014(UTC)
ClementN
#48 Posted : Saturday, June 21, 2014 4:54:05 PM(UTC)
ClementN
Romania
What really happens with the Fullscreen 2 when we only have an extra monitor ?
There are 2 options in my tests:
a) Choose the "Settings" -> "Display" -> "Output Screen" as a non existent display ( ex. 3 or 4 )
In this case, the full screen is displayed on the main monitor under the vMix window
b) Choose the "Settings" -> "Display" -> "Output Screen" as no 2 (same as Full Screen one) .
I want to avoid the case a) but also I want to make sure that having both FullScreen 1 and FullScreen 2 set for same "Output Screen" will not bring any conflicts or other surprises..
Thanks,
nandhitv
#49 Posted : Sunday, June 22, 2014 2:01:24 AM(UTC)
nandhitv
Talent low quality when zoomup and talent not reflecting
Screen reflection also not clear
TVIason
#50 Posted : Sunday, June 22, 2014 6:58:45 AM(UTC)
TVIason
Was thanked: 9 time(s) in 8 post(s)
Keep in mind it's an example of how powerfull uv maps can be. If you want a better virtualset you can buy it or make it. The reason why the talent is unsharp is because you are zooming in on a video if hou output in 1080 your talents camera is in 1080 and you'll zoom in, you'll lose quality. This isn't a problem of te virtual set.
nandhitv
#51 Posted : Sunday, June 22, 2014 7:36:52 AM(UTC)
nandhitv
Talent Good quality in vmix 12
#52 Posted : Sunday, June 22, 2014 9:54:58 AM(UTC)
That set is just an example of how UV maps work. The talent quality will be fine for all the other sets
and sets you can purchase from virtualsetworks.
#53 Posted : Monday, June 23, 2014 2:53:36 AM(UTC)
A new Beta update can now be downloaded (13.0.0.104)
http://www.vmix.com.au/download/vmix13preview.exe
This includes a lot of updates and fixes, including the audio updates discussed in the other thread.
peterphelan on 6/23/2014(UTC), madness on 6/23/2014(UTC)
TVIason
#54 Posted : Monday, June 23, 2014 5:54:07 AM(UTC)
TVIason
First thank you for the new feautures, but I have 2 questions:
-How do you pin in the audio meters when you've pined them out?
-In the last version I had put my headphones in and set them up as headphone output and my speakers as speakers output, but now only one at the time gives a signal so that I can't use the AB, Solo and master properly.
EDIT:
Second question has been solved. You have to restart the program.
peterphelan
#55 Posted : Monday, June 23, 2014 7:33:21 AM(UTC)
peterphelan
I haven't tried this latest update yet, but in the previous one you just "minimise" the mixer screen - I had it moved to second display - and it will pop back into its normal docked position inside vMix. In my case back on my main screen.
Peter
joe1378
#56 Posted : Monday, June 23, 2014 12:20:35 PM(UTC)
joe1378
Martin..thanks for this awesome program
last night I made this effect with lumakey and black and white .xaml
http://forums.vmix.com.a...p;m=10402&#post10402
I noticed that when I assign a .xaml file as lumakey in a video works with the cropping effect. but if I change that .xaml file to another video doesn't work....and check again with the first video and works well. the lumakey-xaml. I think the xaml get marriage with the fitst video that you assign.
I dont know if I explained correctly.
is a glitch or lumakey works in that order
Josue Olvera
ClementN
#57 Posted : Monday, June 23, 2014 4:17:41 PM(UTC)
ClementN
Romania
Excellent work, Martin! Excellent results! I spent my entire weekend with the new vMix :)
I didn't noticed any problem with 13....104 in my tests.
However, I have a small suggestion.
Probably will be usefull to signal active live streaming on the lower-right corner of main screen just like you do with the REC and EXT .
macgiver76
#58 Posted : Tuesday, June 24, 2014 2:53:34 AM(UTC)
macgiver76
For Aja Kona LHE:
Ok for SDI Input;
Not work for SDI Output.
With vmix 13 - Windows Seven 64 bit - Aja Driver 5.5.2
Thank!
#59 Posted : Tuesday, June 24, 2014 12:33:10 PM(UTC)
macgiver76,
Are there any error messages when using it as an output?
macgiver76
#60 Posted : Tuesday, June 24, 2014 1:01:43 PM(UTC)
macgiver76
Hello Martin I did other tests. The SDI output will only work if the setup Pal 50i.
If setup 25p does not work.
The card Aja Kona lhe includes 2 independent SDI outputs. It only works on the first output.
Vmix returns no error.
Thank you for the work done.
Guest (20)
Similar Topics
vMix 13 preview Shortcut key issue (General Discussion)
by IceStream 6/18/2014 7:05:42 PM(UTC)
10 Pages<12345>»
