Martin, When using v13 I frequently set 50i instead of 50p as I add new camera inputs.
In v12 the order for frame rate settings is: 50i or 25p 50p and so on...
In v13 there is a sligt change, namely 50i 25p 50p and so on...
At least for my sore eyes it is very easy to ignore the little "i". May I humbly suggest: 25p 50i 50p
(It would probably to go far and use 25 progressive, 50 interlaced, 50 progressive altough more distinguishable)
Thanks.
Joined: 9/16/2013(UTC) Posts: 27 Location: Lagos, Nigeria
Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
 1 user thanked GBIM for this useful post.
Hello Martin, Why are we not getting any reply on uv mapping reflection demo? or Is it not included in the Vmix 13 Preview Version Yet?
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
UV mapping works, there just isn't a demo set available yet. You can purchase a set from http://www.virtualsetworks.com and request it in vMix format which includes UV mapping/reflections if you like.
Any news or a list on what capture cards are going to be compatible with vmix 13?
admin wrote:UV mapping works, there just isn't a demo set available yet. You can purchase a set from http://www.virtualsetworks.com and request it in vMix format which includes UV mapping/reflections if you like. Please make one simple set for demo. we will learn from it
Joined: 5/7/2012(UTC) Posts: 185  Location: Bucharest Thanks: 48 times Was thanked: 13 time(s) in 11 post(s)
What really happens with the Fullscreen 2 when we only have an extra monitor ?
There are 2 options in my tests:
a) Choose the "Settings" -> "Display" -> "Output Screen" as a non existent display ( ex. 3 or 4 )
In this case, the full screen is displayed on the main monitor under the vMix window
b) Choose the "Settings" -> "Display" -> "Output Screen" as no 2 (same as Full Screen one) .
I want to avoid the case a) but also I want to make sure that having both FullScreen 1 and FullScreen 2 set for same "Output Screen" will not bring any conflicts or other surprises..
Thanks,
Talent low quality when zoomup and talent not reflecting  Screen reflection also not clear
Joined: 11/7/2013(UTC) Posts: 66 Location: Netherlands
Thanks: 21 times Was thanked: 9 time(s) in 8 post(s)
nandhitv wrote:Talent low quality when zoomup and talent not reflecting
Keep in mind it's an example of how powerfull uv maps can be. If you want a better virtualset you can buy it or make it. The reason why the talent is unsharp is because you are zooming in on a video if hou output in 1080 your talents camera is in 1080 and you'll zoom in, you'll lose quality. This isn't a problem of te virtual set.
TVIason wrote:nandhitv wrote:Talent low quality when zoomup and talent not reflecting
Keep in mind it's an example of how powerfull uv maps can be. If you want a better virtualset you can buy it or make it. The reason why the talent is unsharp is because you are zooming in on a video if hou output in 1080 your talents camera is in 1080 and you'll zoom in, you'll lose quality. This isn't a problem of te virtual set. Talent Good quality in vmix 12
nandhitv wrote: Talent Good quality in vmix 12
That set is just an example of how UV maps work. The talent quality will be fine for all the other sets and sets you can purchase from virtualsetworks.
First thank you for the new feautures, but I have 2 questions: -How do you pin in the audio meters when you've pined them out? -In the last version I had put my headphones in and set them up as headphone output and my speakers as speakers output, but now only one at the time gives a signal so that I can't use the AB, Solo and master properly. EDIT: Second question has been solved. You have to restart the program.
Joined: 8/3/2013(UTC) Posts: 30   Location: SW England Thanks: 12 times Was thanked: 4 time(s) in 4 post(s)
I haven't tried this latest update yet, but in the previous one you just "minimise" the mixer screen - I had it moved to second display - and it will pop back into its normal docked position inside vMix. In my case back on my main screen.
Peter
Thanks: 1 times Was thanked: 4 time(s) in 3 post(s)
Martin..thanks for this awesome program last night I made this effect with lumakey and black and white .xaml http://forums.vmix.com.a...p;m=10402&#post10402I noticed that when I assign a .xaml file as lumakey in a video works with the cropping effect. but if I change that .xaml file to another video doesn't work....and check again with the first video and works well. the lumakey-xaml. I think the xaml get marriage with the fitst video that you assign. I dont know if I explained correctly. is a glitch or lumakey works in that order Josue Olvera
Excellent work, Martin! Excellent results! I spent my entire weekend with the new vMix :) I didn't noticed any problem with 13....104 in my tests.
However, I have a small suggestion.
Probably will be usefull to signal active live streaming on the lower-right corner of main screen just like you do with the REC and EXT .
Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
For Aja Kona LHE:
Ok for SDI Input; Not work for SDI Output.
With vmix 13 - Windows Seven 64 bit - Aja Driver 5.5.2
Thank!
macgiver76,
Are there any error messages when using it as an output?
Hello Martin I did other tests. The SDI output will only work if the setup Pal 50i. If setup 25p does not work. The card Aja Kona lhe includes 2 independent SDI outputs. It only works on the first output. Vmix returns no error. Thank you for the work done.
