Joined: 9/13/2016(UTC) Posts: 118   Location: Ukraine Thanks: 6 times Was thanked: 5 time(s) in 4 post(s)
Hello. When Title Designer as a background can be used with a video animation or an alpha channel ?? Still images are too boring. Thank you.
Joined: 10/23/2015(UTC) Posts: 458   Thanks: 20 times Was thanked: 231 time(s) in 130 post(s)
@Murchik, you can use small hack to show PNG sequences, but that's need a lot of work by your hands =) Code:<UserControl x:Class="AnimatedHD"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
mc:Ignorable="d" Width="1920" Height="1080" xmlns:my="clr-namespace:vMixTitleLibrary;assembly=vMixTitleLibrary">
<UserControl.Resources>
<Storyboard x:Key="Storyboard1" Duration="0:0:5">
<StringAnimationUsingKeyFrames Storyboard.TargetProperty="Text" Storyboard.TargetName="rHeadline">
<DiscreteStringKeyFrame KeyTime="0:0:00.00" Value="Test_1000.png"/>
<DiscreteStringKeyFrame KeyTime="0:0:00.03" Value="Test_1001.png"/>
<DiscreteStringKeyFrame KeyTime="0:0:00.07" Value="Test_1002.png"/>
<DiscreteStringKeyFrame KeyTime="0:0:04.93" Value="Test_1148.png"/>
<DiscreteStringKeyFrame KeyTime="0:0:04.97" Value="Test_1149.png"/>
</StringAnimationUsingKeyFrames>
</Storyboard>
<Storyboard x:Key="Storyboard2" Duration="0:0:5">
<DiscreteStringKeyFrame KeyTime="0:0:00.00" Value="Test_1149.png"/>
<DiscreteStringKeyFrame KeyTime="0:0:00.03" Value="Test_1148.png"/>
<DiscreteStringKeyFrame KeyTime="0:0:04.93" Value="Test_1001.png"/>
<DiscreteStringKeyFrame KeyTime="0:0:04.97" Value="Test_1000.png"/>
</Storyboard>
</UserControl.Resources>
<UserControl.Triggers>
<EventTrigger RoutedEvent="FrameworkElement.Loaded">
<BeginStoryboard Storyboard="{StaticResource Storyboard1}"/>
</EventTrigger>
</UserControl.Triggers>
<Grid Background="Black">
<my:TextBlockDesign Name="rHeadline" Text="Test_1000.png"/>
<Image Source="{Binding Text, ElementName=rHeadline}"/>
</Grid>
</UserControl>
Hi Murchik As is Title Designer won't let you build titles with animations or videos as a background. As Elgarf showed, you can use Expression Blend (from MS Visual Studio) to create more sophisticated xaml titles. You can also take advantage of every feature vMix has, for example alpha channel support, to create your animated title in Adobe After Effect (or else) and feed vMix over NDI or as an alpha video. I explained this solution yesterday, check this topic: http://forums.vmix.com/d....aspx?g=posts&t=8812and search the forum. Many other solutions have already been discussed.
