Murchik
#1 Posted : Wednesday, February 1, 2017 9:33:43 PM(UTC)
Murchik
Ukraine
Hello. When Title Designer as a background can be used with a video animation or an alpha channel ?? Still images are too boring. Thank you.
elgarf
#2 Posted : Thursday, February 2, 2017 4:47:47 AM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
@Murchik, you can use small hack to show PNG sequences, but that's need a lot of work by your hands =)
Code:
<UserControl x:Class="AnimatedHD"
             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
             xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
             xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
             mc:Ignorable="d" Width="1920" Height="1080" xmlns:my="clr-namespace:vMixTitleLibrary;assembly=vMixTitleLibrary">
    <UserControl.Resources>
        <Storyboard x:Key="Storyboard1" Duration="0:0:5">
            <StringAnimationUsingKeyFrames Storyboard.TargetProperty="Text" Storyboard.TargetName="rHeadline">
                <DiscreteStringKeyFrame KeyTime="0:0:00.00" Value="Test_1000.png"/>
					<DiscreteStringKeyFrame KeyTime="0:0:00.03" Value="Test_1001.png"/>
					<DiscreteStringKeyFrame KeyTime="0:0:00.07" Value="Test_1002.png"/>
					<DiscreteStringKeyFrame KeyTime="0:0:04.93" Value="Test_1148.png"/>
					<DiscreteStringKeyFrame KeyTime="0:0:04.97" Value="Test_1149.png"/>
            </StringAnimationUsingKeyFrames>
        </Storyboard>
		<Storyboard x:Key="Storyboard2" Duration="0:0:5">
				<DiscreteStringKeyFrame KeyTime="0:0:00.00" Value="Test_1149.png"/>
				<DiscreteStringKeyFrame KeyTime="0:0:00.03" Value="Test_1148.png"/>
				<DiscreteStringKeyFrame KeyTime="0:0:04.93" Value="Test_1001.png"/>
				<DiscreteStringKeyFrame KeyTime="0:0:04.97" Value="Test_1000.png"/>
        </Storyboard>
    </UserControl.Resources>
    <UserControl.Triggers>
        <EventTrigger RoutedEvent="FrameworkElement.Loaded">
            <BeginStoryboard Storyboard="{StaticResource Storyboard1}"/>
        </EventTrigger>
    </UserControl.Triggers>
    <Grid Background="Black">
        <my:TextBlockDesign Name="rHeadline" Text="Test_1000.png"/>
        <Image  Source="{Binding Text, ElementName=rHeadline}"/>
    </Grid>
</UserControl>
#3 Posted : Thursday, February 2, 2017 5:58:39 AM(UTC)
Hi Murchik
As is Title Designer won't let you build titles with animations or videos as a background.
As Elgarf showed, you can use Expression Blend (from MS Visual Studio) to create more sophisticated xaml titles.
You can also take advantage of every feature vMix has, for example alpha channel support, to create your animated title in Adobe After Effect (or else) and feed vMix over NDI or as an alpha video.
I explained this solution yesterday, check this topic:
http://forums.vmix.com/d....aspx?g=posts&t=8812
and search the forum. Many other solutions have already been discussed.
Similar Topics
Enable JPEG in GT Title Designer (Feature Requests)
by offroadmediagroup 11/3/2026 2:59:29 AM(UTC)
GT Title Designer - allow it to parse HTML Markup from a datasource (Feature Requests)
by Hypohamish 3/23/2026 11:19:46 PM(UTC)
"How can I do this through the Title Designer program?" (GT)
by bulent_atlas 6/26/2025 11:11:42 PM(UTC)
Allow for Alpha values on Layers in GT Title Designer (Feature Requests)
by offroadmediagroup 4/9/2025 8:42:08 AM(UTC)
Allow for nested layers within GT Title Designer (Feature Requests)
by offroadmediagroup 4/9/2025 8:36:47 AM(UTC)
Make GT Title Designer Locking Layers ACTUALLY Lock (Feature Requests)
by offroadmediagroup 4/9/2025 8:18:59 AM(UTC)
Allow Multi-Selected Layers Feature Changes in GT Title Designer (Feature Requests)
by offroadmediagroup 4/3/2025 3:30:15 PM(UTC)
Update Default Behavior to Move via Arrows in GT Title Designer (Feature Requests)
by offroadmediagroup 4/3/2025 2:21:05 PM(UTC)
Retain Order When Copy/Pasting Layers in GT Title Designer (Feature Requests)
by offroadmediagroup 4/3/2025 2:10:15 PM(UTC)
GT Title Designer not importing PSDs with text in it (GT)
by Woogi 3/22/2025 8:22:39 AM(UTC)
GT Title Designer "Snap to" Safe Zone (Feature Requests)
by WaltG12 9/21/2024 5:59:44 AM(UTC)
vMix GT Title Designer (GT)
by Seetha Ramaiah Velicheti 7/20/2024 6:51:44 PM(UTC)
Adaptive Table for GT Title Designer (Feature Requests)
by scronk03 4/19/2024 3:12:55 AM(UTC)
GT title designer transitionin (GT)
by Pepsi(~) 4/19/2024 1:01:11 AM(UTC)
Feature in GT Title Designer and DataSource (Feature Requests)
by Ham4u62 3/27/2024 12:07:21 AM(UTC)
GT Title Designer NO FUNCIONA CON AMD (GT)
by angel guerrero 2/23/2024 10:16:46 AM(UTC)
GT Title Designer - image sequence (Feature Requests)
by AndrzejK 12/26/2023 8:54:40 AM(UTC)
GT Title Designer Request (Feature Requests)
by Simsyuk 2/24/2023 12:43:38 AM(UTC)
Can't launch GT Title Designer for some reason. (GT)
by ralston 2/2/2023 10:24:07 AM(UTC)
Add Keyboard Shortcuts for GT Title Designer (Feature Requests)
by jameslex 1/27/2023 12:43:41 AM(UTC)
Different Font settings within the same field in Title designer (Feature Requests)
by Paul Camino 9/12/2022 2:02:28 PM(UTC)
GT Title Designer - Auto sized right align text (Feature Requests)
by Huwenator 6/21/2022 3:10:31 PM(UTC)
Animatable layer position in GT Title Designer (Feature Requests)
by Mr. Broadcast 5/10/2022 9:24:41 PM(UTC)
关于 GT Title Designer 的几点建议 (Feature Requests)
by nthjz 3/31/2022 12:23:29 PM(UTC)
line height in GT Title Designer (Feature Requests)
by PDU_Mikhail 3/3/2022 4:23:05 AM(UTC)
☝️ Leading Option in vMix GT Title Designer (Feature Requests)
by Pointer 2/1/2022 4:24:37 AM(UTC)
GT Title Designer Bounding Limits (Feature Requests)
by Ryan_AlleganyMedia 10/27/2021 11:25:09 AM(UTC)
Auto squeeze text - GT title designer (Feature Requests)
by Hylkewolf 1/11/2021 8:15:43 PM(UTC)
Standalone GT Title Designer (3rd Party Software and Development)
by rhodian 10/26/2020 6:03:23 PM(UTC)
Colour Picker in GT Title Designer (Feature Requests)
by colintve 10/14/2020 8:35:26 AM(UTC)
