teamonewheel@googlemail.com
#1 Posted : Monday, November 19, 2012 10:17:09 AM(UTC)
Hiya im having problems getting a external screen to work via hdmi HELP??
Steadirob
#2 Posted : Tuesday, November 20, 2012 12:45:19 AM(UTC)
Steadirob
Did you choose the right display number on the "Display" tab of the Settings?
You have probably several numbers there at the Output Screen option and need to choose one, then quit and restart the program. One of those numbers should correspond with the hdmi connected.
Number 1 is often the first Desktop screen so when you make the application window smaller it will be on the desktop, behind vMix.
Rob
Guest (4)
Similar Topics
HDMI Output to Teradeck Wave (Hardware Compatibility)
by fingerlakes1 11/30/2021 7:58:28 AM(UTC)
AJA Kona 4 HDMI OUTPUT ISSUE (General Discussion)
by martyp 2/29/2020 7:44:06 AM(UTC)
HDMI output issue (Hardware Compatibility)
by puruzio 11/5/2019 2:03:19 PM(UTC)
GTX 1060 6GB OC can provide 1080i50 HDMI output? (Hardware Compatibility)
by guztavo 10/1/2019 1:40:02 AM(UTC)
Magewell Quad HDMI output resolution (Hardware Compatibility)
by -TA_ 9/6/2017 6:59:57 AM(UTC)
Olympus E-M5ii HDMI output won't show up in VMix (Hardware Compatibility)
by lael 2/18/2017 6:24:32 AM(UTC)
hdmi output (General Discussion)
by mattymyto 1/19/2016 5:54:02 PM(UTC)
Does Vmix support HDMI output to TV display? (General Discussion)
by Broadcasting27 2/26/2013 6:53:16 AM(UTC)
