teamonewheel@googlemail.com
#1 Posted : 13 years ago
Hiya im having problems getting a external screen to work via hdmi HELP??
Steadirob
#2 Posted : 13 years ago
Steadirob
Did you choose the right display number on the "Display" tab of the Settings?
You have probably several numbers there at the Output Screen option and need to choose one, then quit and restart the program. One of those numbers should correspond with the hdmi connected.
Number 1 is often the first Desktop screen so when you make the application window smaller it will be on the desktop, behind vMix.
Rob
Similar Topics
HDMI Output to Teradeck Wave (Hardware Compatibility)
by fingerlakes1 3 years ago
AJA Kona 4 HDMI OUTPUT ISSUE (General Discussion)
by martyp 5 years ago
HDMI output issue (Hardware Compatibility)
by puruzio 6 years ago
GTX 1060 6GB OC can provide 1080i50 HDMI output? (Hardware Compatibility)
by guztavo 6 years ago
Magewell Quad HDMI output resolution (Hardware Compatibility)
by -TA_ 8 years ago
Olympus E-M5ii HDMI output won't show up in VMix (Hardware Compatibility)
by lael 8 years ago
hdmi output (General Discussion)
by mattymyto 9 years ago
Does Vmix support HDMI output to TV display? (General Discussion)
by Broadcasting27 12 years ago
