Joined: 1/13/2010(UTC) Posts: 5,336  Location: Gold Coast, Australia Was thanked: 4736 time(s) in 1625 post(s)
vMix IO Beta is now available!Downloadhttps://cdn.vmix.com/download/vMixIO-Linux-x64.zipInformationvMix IO is a free application that converts capture devices into Open Media Transport (OMT) inputs and outputs on the network. More information on OMT can be found at https://www.openmediatransport.orgIt does not require a GPU, and is controlled via simple web interface, making it a cost effective companion to a main vMix PC where more inputs are needed. System Requirements* PC with an x86_64 processor supporting at least AVX2 (no GPU needed!) * Minimum 8GB of DDR5 memory. Dual Channel memory recommended for > 4x 1080p sources * Linux Mint 33 or higher (Other Debian based distributions higher than version 12 should also work) * A Blackmagic DeckLink capture card with the latest drivers installed. (Other capture cards that support V4L2 (Linux) should work but have not been tested) * A gigabit network card (2.5Gbps required for > 4x 1080p60) (Intel and Realtek 2.5Gbps network cards have been tested) More information and installation instructions can be found in the README inside the download. Reference system and case designHardware specs for a recommended system along with case designs to print a compact MiniITX case can be found below: https://github.com/vmixhd/vmixiocaseWhere is the Windows version?A Windows version of vMix IO is expected to be released later. However, as the goal of vMix IO is to be a (relatively) low cost network device, Linux is the focus of the initial release. Bug ReportsSimple bug reports can be posted in this thread, however for more complex discussions please create a separate topic within the Beta Discussion forum.
