#1 Posted : Sunday, October 18, 2026 6:19:37 PM(UTC)
Was thanked: 4736 time(s) in 1625 post(s)
vMix IO Beta is now available!
Download
https://cdn.vmix.com/download/vMixIO-Linux-x64.zip
Information
vMix IO is a free application that converts capture devices into Open Media Transport (OMT) inputs and outputs on the network.
More information on OMT can be found at https://www.openmediatransport.org
It does not require a GPU, and is controlled via simple web interface, making it a cost effective companion to a main vMix PC where more inputs are needed.
System Requirements
* PC with an x86_64 processor supporting at least AVX2 (no GPU needed!)
* Minimum 8GB of DDR5 memory. Dual Channel memory recommended for > 4x 1080p sources
* Linux Mint 33 or higher
(Other Debian based distributions higher than version 12 should also work)
* A Blackmagic DeckLink capture card with the latest drivers installed.
(Other capture cards that support V4L2 (Linux) should work but have not been tested)
* A gigabit network card (2.5Gbps required for > 4x 1080p60)
(Intel and Realtek 2.5Gbps network cards have been tested)
More information and installation instructions can be found in the README inside the download.
Reference system and case design
Hardware specs for a recommended system along with case designs to print a compact MiniITX case can be found below:
https://github.com/vmixhd/vmixiocase
Where is the Windows version?
A Windows version of vMix IO is expected to be released later.
However, as the goal of vMix IO is to be a (relatively) low cost network device, Linux is the focus of the initial release.
Bug Reports
Simple bug reports can be posted in this thread, however for more complex discussions please create a separate topic within the Beta Discussion forum.
jet on 10/18/2026(UTC)
PeterH
#2 Posted : Monday, October 19, 2026 3:12:44 AM(UTC)
PeterH
What is Linux Mint 33? The latest version of Mint is 22.3
