Joined: 1/13/2010(UTC) Posts: 5,373  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
vMix IO Beta is now available!Downloadhttps://cdn.vmix.com/download/vMixIO-Linux-x64.zipInformationvMix IO is a free application that converts capture devices into Open Media Transport (OMT) inputs and outputs on the network. More information on OMT can be found at https://www.openmediatransport.orgIt does not require a GPU, and is controlled via simple web interface, making it a cost effective companion to a main vMix PC where more inputs are needed. System Requirements* PC with an x86_64 processor supporting at least AVX2 (no GPU needed!) * Minimum 8GB of DDR5 memory. Dual Channel memory recommended for > 4x 1080p sources * Linux Mint 22.3 or higher (Other Debian based distributions higher than version 12 should also work) * A Blackmagic DeckLink capture card with the latest drivers installed. (Other capture cards that support V4L2 (Linux) should work but have not been tested) * A gigabit network card (2.5Gbps required for > 4x 1080p60) (Intel and Realtek 2.5Gbps network cards have been tested) More information and installation instructions can be found in the README inside the download. Reference system and case designHardware specs for a recommended system along with case designs to print a compact MiniITX case can be found below: https://github.com/vmixhd/vmixiocaseWhere is the Windows version?A Windows version of vMix IO is expected to be released later. However, as the goal of vMix IO is to be a (relatively) low cost network device, Linux is the focus of the initial release. Bug ReportsSimple bug reports can be posted in this thread, however for more complex discussions please create a separate topic within the Beta Discussion forum.
 4 users thanked admin for this useful post.
What is Linux Mint 33? The latest version of Mint is 22.3
Thanks for spotting that. It is a typo it should be 22.3
Joined: 10/24/2026(UTC) Posts: 5  Was thanked: 2 time(s) in 2 post(s)
Briefly tested vMix IO on a Debian 13 Trixie (virtual) machine. Needed to install the following additional packaghes: Code:sudo apt install libsamplerate0 webp avahi-daemon libavahi-client3 libasound2t64
And to get vMix IO up and running: Code:
sudo apt install unzip
sudo mkdir -p /opt/vmix-io && cd /opt/vmix-io
wget https://cdn.vmix.com/download/vMixIO-Linux-x64.zip
sudo unzip vMixIO-Linux-x64.zip
sudo chmod +x vMixIO
sudo ./vMixIO
I tested with a Decklink 8K and Decklink IP. For this the following steps are required: Code:
sudo apt install build-essential dkms linux-headers-$(uname -r)
tar -xvf Blackmagic_Desktop_Video_Linux_*.tar
cd Blackmagic_Desktop_Video_Linux_*/deb/x86_64/
sudo dpkg -i desktopvideo_*_amd64.deb
sudo apt install -f
After this I was able to start vMix IO, define some Inputs and take the OMT feeds in vMix. I was not able to test the Outputs because the Decklink cards require a UI/X-server and I'm running a headless (virtual) machine.
 1 user thanked jorisdv for this useful post.
Testing with Linux Mint and SDI-connected camera via BMD Mini Monitor 4K (Didn't have a DUO2 or Quad2 on hand at the moment).
IO Input 1 shows up as 1080p29.97 regardless of the camera settings (1080p59.94, 1080p60).
Is this a feature or a bug or OE?
- Tom
When creating the input in the web interface, did you leave the format set to "Auto"? If so, this will rely on the signal detection of the card itself, and on some older cards this may not be available.
If the input provides vMix IO with no signal detection, then you will need to manually specify the format when adding.
Martin vMix
Originally Posted by: admin  When creating the input in the web interface, did you leave the format set to "Auto"? That's what I thought as well. So I tried 1080p59.94 and the input reverted to 1080p29.97 after a second or two. Tried some other resolutions/frame rates with the same result. I have a Duo2 arriving this weekend. I'll try it and report. -Tom
That would appear to indicate it is detecting that as the signal of the source. Does it show a picture at all or does it only show blank? Can you verify what the signal format is in Media Express when vMix IO is not running?
Originally Posted by: admin  Does it show a picture at all or does it only show blank? Can you verify what the signal format is in Media Express when vMix IO is not running? It shows a picture. About one frame per 5 second. Signal format in Media Express is 1080p29.97. Verified camera is set for 1080p59.94.
Ok that seems correct then. vMix IO can't do any format conversions, so if Media Express shows 1080p2997 then that is the actual format of the source connected and what vMix IO will use. Otherwise the picture would be blank.
Joined: 11/14/2012(UTC) Posts: 414  Location: Finland Thanks: 273 times Was thanked: 40 time(s) in 38 post(s)
Originally Posted by: admin  vMix IO is a free application that converts capture devices into Open Media Transport (OMT) inputs and outputs on the network. More information on OMT can be found at https://www.openmediatransport.org Is 4K supported by vMix IO? Kind regards, Jani
UPDATE
Removed Decklink Mini Monitor 4K and installed Decklink Duo 2. Added a 2nd SDI camera (BirdDog P120 1080p59.94) as Input 3. First camera is PTZ Optics Move 4K 12X at 1080p29.97 as Input 4. (Inputs 1 & 2 were added as ports 1 & 2 but are black as no camera is selected.
(I love how the Add Input automatically advances to the next Device available. Very nice.)
Used Auto format and Quality set to High on both camera Inputs. In vMix, all four Inputs were added.
At Home screen, Input 3 shows an image and correct resolution/frame rate, but shows zero Connections.
In Statistics, Input 3 (P120) does not show up. Zeros across each category. Input 4 (PTZO) shows data in each category.
Deleted Input 3 in vMix and re-added. Now shows up as 2 Connections and also shows in Statistics.
All in all -- Pretty Slick!
Interesting side note: If I close Firefox in Linux, the vMix production still shows the active cameras. If I start FF again and navigate to the vMix IO URL, all four Inputs appear in FF as soon as I log in.
- Tom
 1 user thanked sinc747 for this useful post.
Possible Bug
Removed Input 3 (P120) at High Quality. Replaced it with same camera using Auto quality. Noticed that the default Input number was not 3, but 4. Still added it. Now I have two Input 4's, one for P120 and one for PTZO camera. The P120 Input 4 shows 0 Connections and is also not available in vMix as a OMT source.
If I remove that IO Input and re-add it, but edit the Input number from the default (4) to 3. Everything works properly.
- Tom
vMix IO 1.0.0.1 Beta released!https://cdn.vmix.com/download/vMixIO-Linux-x64.zip* Fixed issue with duplicate names on inputs * Fixed audio on outputs failing randomly on DeckLink cards * Fixed install service script not working correctly * Added version number to top right hand corner of web site to quickly identify if latest is installed.
 3 users thanked admin for this useful post.
Joined: 12/28/2021(UTC) Posts: 10  Location: London Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
I used the latest Decklink driver and it worked fine for a Decklink Duo, but the latest driver can't see my Decklink Quad cards - how far back can I go with Decklink video driver/software?
Originally Posted by: PlayLIVE  I used the latest Decklink driver and it worked fine for a Decklink Duo, but the latest driver can't see my Decklink Quad cards - how far back can I go with Decklink video driver/software?
Linux Mint 22.3, Decklink drivers 16.5 Decklink card running the 16.4 firmware (16.5 doesn't work on the quads on windows or linux it seems). All working OK. Added latency from OMT receive, SDI out to SDI in and OMT transmit is 6 frames..... NICE, thanks vMix. Small feature requests - can we have buttons in the web interface to change the SDI connector modes from SDI 1+2 to SDI 1 to avoid having to use the Desktop GUI? A quick ChatGPT led me to "Blackmagic exposes this through IDeckLinkConfiguration and the bmdDeckLinkConfigDuplexMode setting." This would affect all of the Decklink SDI cards I believe. In terms of system usage, the 4c8t and 8GB of RAM (DDR4 - single channel) for 1 output and 1 input use about 20% combined CPU usage, RAM sitting at 2.5GB (inc OS), Big Buck Bunny using about 184Mb/s of traffic each way. Another feature request - It would be great to also be able to monitor the CPU and Memory and Network usage over the network, happy to help draw this up - I have something for PHP that does this but this is not PHP. Another feature request - A shutdown button in the web interface.
 1 user thanked PlayLIVE for this useful post.
