cody@raceontexas.com
#1 Posted : Wednesday, May 3, 2023 5:13:40 AM(UTC)
I would like to be able to add up to 20 layers per input. 10 is okay, but I do events where I have many logos that I need to toggle off and on and being able to load more into the input and toggle between them would be great. 10 is just not enough.
#2 Posted : Wednesday, May 3, 2023 5:25:22 AM(UTC)
WHat about creating some GT titles where logos (images) are layered and turned on/off . considering using adatasource to switch to the logos you want to be visible . Of course dependent on their locations in the view but are a few posibilities
btw similar request has been made in this forum some years ago
#3 Posted : Wednesday, May 3, 2023 5:27:19 AM(UTC)
I am interested, is there a video anywhere showing how to do this?
#4 Posted : Wednesday, May 3, 2023 5:30:52 AM(UTC)
well an idea (details) of a layout and what to change etc would be helpfull. position on the view are sort of important to find a good option. I have many logos that I need to toggle off and on and being able to load more into the input is kind of broad
#5 Posted : Wednesday, May 3, 2023 5:34:34 AM(UTC)
I work for a broadcasting company that does racing events and we have many remote producers and film at many tracks. What I am wanting to do it make it so I can add all the track logos into the input as layers and do scripts and shortcuts to our stream decks do instead of them having to go to every input that uses the logo they can just click a button and it swap the track logo they are at for that event.
#6 Posted : Wednesday, May 3, 2023 5:53:30 AM(UTC)
if i understand correctly: ( a visual is always easier) use a title and switch the logo using a datasource (row of data is per event). just need to seelct the correct row of the datasource.
One datasource, One title (no 20 layers needed)
#7 Posted : Wednesday, May 3, 2023 5:55:14 AM(UTC)
Okay I will give this a try.
RichShumaker
#8 Posted : Wednesday, May 10, 2023 1:07:21 PM(UTC)
RichShumaker
Was thanked: 28 time(s) in 23 post(s)
The workaround is Nested Layers.
I have hit the 10 layer input ceiling a lot so I started breaking my content into sections to allow me to not hit that ceiling.
So if I need 16 things on screen I see if there is a natural break and use that.
If Not I figure out what is on top of what and then go that way.
What has helped me with this is Mix Input and Central Control.
I don't think I can explain easily how both help so I guess take my word for it?(Sorry I can't give more details with words on this)
Also I am working out bugs and kinks as we are in Pre-Production for our next season so this is a fluid answer as it has changed over the past 3 seasons as new features come out. A good example is Mix Input which did not exist when we started and does now.
#9 Posted : Wednesday, May 10, 2023 1:15:07 PM(UTC)
I ended up using this:
Function=SetMultiViewOverlay&Input=My input&Value=1,My new overlay source input
in a script and did a page on my stream deck for the logos I wanted to use and it swaps out the logo in layer 1 for that input.
vishwa.prakash
#10 Posted : Saturday, May 13, 2023 9:38:41 PM(UTC)
vishwa.prakash
India
+1
Similar Topics
Fade on playlist and layers & Sys info input for multiview (Feature Requests)
by emet 8/3/2026 8:42:43 PM(UTC)
GT Designer - Stacked Layers (Feature Requests)
by PiateZebedee 7/21/2026 9:03:56 AM(UTC)
Layers in XML (Feature Requests)
by VasaA-V 4/15/2026 12:01:26 AM(UTC)
Resize layers from MIDI control (General Discussion)
by 3579865 2/16/2026 11:04:21 AM(UTC)
Perspective/Corner Warp Transform for Layers (Feature Requests)
by Filip96 12/29/2025 9:31:34 AM(UTC)
Prevent dragging layers in virtual set setup? (General Discussion)
by TBacker 8/22/2025 6:34:22 AM(UTC)
Missing new Overlay/Transition layers for Input Mouse Click action (FIXED) (Beta Discussion)
by ryxyz 8/16/2025 11:52:08 PM(UTC)
layers s (Feature Requests)
by mehmet turfullu 8/10/2025 12:33:21 AM(UTC)
Provide options to zoom/pan layers with pixels! (Feature Requests)
by offroadmediagroup 8/7/2025 5:57:14 AM(UTC)
ACTIVATING AND DEACTIVATING TRANSITIONS IN GTZIP/XAML WHEN USING THEM IN THE 10 LAYERS OF EACH INPUT (Feature Requests)
by DDJ 7/14/2025 2:02:18 AM(UTC)
Dimension Bars in Small Layers (Feature Requests)
by gutozin 5/16/2025 8:33:26 AM(UTC)
Central Control with vmix layers using APC40MKII (3rd Party Software and Development)
by Trilback 5/6/2025 12:32:27 PM(UTC)
Allow for Alpha values on Layers in GT Title Designer (Feature Requests)
by offroadmediagroup 4/9/2025 8:42:08 AM(UTC)
Allow for nested layers within GT Title Designer (Feature Requests)
by offroadmediagroup 4/9/2025 8:36:47 AM(UTC)
Make GT Title Designer Locking Layers ACTUALLY Lock (Feature Requests)
Belarus offroadmediagroup 4/9/2025 8:18:59 AM(UTC)
Allow Multi-Selected Layers Feature Changes in GT Title Designer (Feature Requests)
by offroadmediagroup 4/3/2025 3:30:15 PM(UTC)
Retain Order When Copy/Pasting Layers in GT Title Designer (Feature Requests)
by offroadmediagroup 4/3/2025 2:10:15 PM(UTC)
Align and distribute layers , drop shadow (Feature Requests)
by JDroadie 2/21/2025 2:12:56 PM(UTC)
Dynamically hiding layers on an input (with animations) (General Discussion)
by offbeat 2/16/2025 12:51:55 AM(UTC)
Merge anomalies with Flattened Layers, PTZ and Layers (Beta Discussion)
by Highway20Productions 1/16/2025 3:42:06 AM(UTC)
Flatten Layers and merge (Beta Discussion)
by dark_ata 11/28/2024 11:02:43 PM(UTC)
Swap input but keep layers assignments (General Discussion)
by mct 11/8/2024 11:09:50 AM(UTC)
vMix 28 - Flatten Layers (Feature Requests)
by spinfold 9/14/2024 5:38:43 AM(UTC)
Cropping Zoom inputs on layers of other inputs (General Discussion)
by knbPixels 9/5/2024 7:31:25 AM(UTC)
Possible bug? Imported PSD Image Layers breaks visibility toggle (GT)
by JakeyBoyPro 5/25/2024 7:33:57 PM(UTC)
EDITING LAYERS (General Discussion)
by GMM 4/28/2024 2:29:11 PM(UTC)
18 layeres ou overlayers (General Discussion)
by lnrdprt 1/25/2024 4:08:53 AM(UTC)
Stealth Editing Multiview/Layers (Feature Requests)
by jeffmvr 10/30/2023 12:28:05 PM(UTC)
Using multiple layers in new input as a new layer does not work (General Discussion)
by marin 10/6/2023 6:52:55 PM(UTC)
Naming Presets in Layers (General Discussion)
by sojorner 9/18/2023 7:54:09 AM(UTC)
